Determine the overall efficiency of a 4 into one gearbox configuration
  • Thread starter Thread starter Pinon1977
    Power transfer
The discussion focuses on calculating the overall efficiency of a four-into-one gearbox configuration, where each gearbox operates at 90% efficiency. With four gearboxes, each receiving one horsepower, the total output power is calculated to be 3.6 kW after accounting for efficiency losses. The importance of creating a Free Body Diagram (FBD) for each gearbox is emphasized to better understand torque and power flow. The initial assumption of achieving 9 horsepower through multiplication of efficiencies is corrected, highlighting the need for accurate calculations. Understanding these principles is crucial for determining the system's efficiency accurately.
Pinon1977
TL;DR Summary
Trying to determine the overall efficiency of a 4 into one gearbox configuration
So I'm trying to figure out the overall efficiency of this particular gear system. I have four gearboxes, each stationary in and of themselves, all driving a central ring gear which is permanently attached to a rotating shaft. Please see the attached sketch. If each one of the perimeter gearboxes is 90% efficient and they're directly feeding a ring gear that is attached permanently to a drive shaft, what would the overall power transfer efficiency be? One more piece of information, each gearbox has an input power of one horsepower. My first guesstimation would be that one horsepower reduced by 90% efficiency would be 9 horsepower.. but then when you multiply 9 x .9 x .9 v .9?
Pinon1977 said:
TL;DR Summary: Trying to determine the overall efficiency of a 4 into one gearbox configuration
If only we could be so lucky, but we do not allow the discussion of free energy machines on PF.
At 90% efficiency, for each 1 kW that flows from an input shaft, through one gearbox, to a common output shaft, 900 watt will appear at the output. With four input shafts, the output power will be 4 * 1 kW * 0.9 = 3.6 kW.
Always the same advice:
jack action said:
Do a Free Body Diagram (FBD) on each gearbox to get the answer.
It would be really beneficial for you to do so. It would help you understand how the torque and power flow through your system.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
