Determine the positive numbers a
In summary, the only positive numbers $a$ such that \sqrt[3]{3+\sqrt{a}}+\sqrt[3]{3-\sqrt{a}} is an integer are a=\frac{368}{27} and a=\frac{242}{27}.
anemone
MHB
POTW Director
3,883
115
Determine the positive numbers $a$ such that \(\displaystyle \sqrt[3]{3+\sqrt{a}}+\sqrt[3]{3-\sqrt{a}}\) is an integer.
Mathematics news on Phys.org
(3 + a^(1/2))^(1/3) + (3 – a^(1/2))^(1/3) is integer
Let (3 + a^(1/2))^(1/3) + (3 – a^(1/2))^(1/3) = -c
So (3 + a^(1/2))^(1/3) + (3 – a^(1/2))^(1/3) +c = 0
As x + y +z = 0 => x^3 + y^3 + z^3 = 3xyz
So (3 + a^(1/2))+ (3 – a^(1/2)) +c^3 = 3c(9-a)
Or c^3 + 6 = 3c(9-a)
C cannot be zero
9-a = (c^3 + 6)/3c or a = 9 – (c^3+6)/(3c) …(1)
Because a is positive we can choose c^3 + 6 > 3c if c is negative and c^3 + 6 < 3c if c is positive
So c^3 + 6 > 3c and c < 0 => c = -2 or – 1
c^3 + 6 < 3c and c > 0 no solutionso c = -2 or =-1 from (1) you can get a = 26/3 or 20/3
Hi kaliprasad,
Thanks for participating but I see that when \(\displaystyle a=\frac{26}{3}\), then \(\displaystyle \sqrt[3]{3+\sqrt{\frac{26}{3}}}+\sqrt[3]{3-\sqrt{\frac{26}{3}}}\ne \text{integer}\)...
And the same applies to the case when \(\displaystyle a=\frac{20}{3}\).
I am sorry. Unable to find the flaw in the logic second solution seems to be 22/3 a calcluation mistake
So (3 + a^(1/2))+ (3 – a^(1/2)) +c^3 = 3c(9-a) I believe this is where it went wrong...
I think you should get \(\displaystyle 3 + a^{\frac{1}{2}}+3 – a^{\frac{1}{2}}+c^3 = 3c(9-a)^{\frac{1}{3}} \), i.e. the factor $(9-a)$ is raised to the one-third power.
I very much like kaliprasad's idea of using the implication $x + y +z = 0 \ \Longrightarrow \ x^3 + y^3 + z^3 = 3xyz.$ So suppose that \(\displaystyle \sqrt[3]{3+\sqrt{a}}+\sqrt[3]{3-\sqrt{a}} = n\). Then \(\displaystyle (3+\sqrt{a})+ (3-\sqrt{a}) + (-n)^3 = 3(-n)\sqrt[3]{9-a}.\) Therefore $\sqrt[3]{9-a} = \dfrac{n^3-6}{3n}$, and $a = 9 - \dfrac{(n^3-6)^3}{27n^3}.$
We are told that $a>0$, so we must have $\dfrac{(n^3-6)^3}{27n^3} < 9$. The function $f(x) = \dfrac{(x-6)^3}{27x}$ is always positive when $x<0$, and has a minimum value $9$ when $x=-3$. When $x>0$, $f(x)$ is an increasing function, and $f(24) = 9$. So the condition $f(n^3) < 9$ implies that $n^3>0$ and $n^3 < 24$. Thus the only integer solutions for $n$ are $n=1$ and $n=2.$
If $n=1$ then $a = 9 - \dfrac{(-5)^3}{27} = \dfrac{368}{27}$. If $n=2$ then $a = 9 - \dfrac1{27} = \dfrac{242}{27}.$ Those are the only two solutions for $a$.
Thanks Opalg for participating and yes, the two values of $a$ that you found are correct, of course!(Sun)
My solution:
Let \(\displaystyle y=\sqrt[3]{3+\sqrt{a}}+\sqrt[3]{3-\sqrt{a}}\) where $y$ is an integer and $a>0$.
Then we have
\(\displaystyle y^3=\left(\sqrt[3]{3+\sqrt{a}}+\sqrt[3]{3-\sqrt{a}}\right)^3\)
\(\displaystyle y^3=\left(3+\sqrt{a}\right)+3(3+\sqrt{a})^{\frac{1}{3}}(3-\sqrt{a})^{\frac{1}{3}}\left(\sqrt[3]{3+\sqrt{a}}+\sqrt[3]{3-\sqrt{a}}\right)+(3-\sqrt{a})\)
\(\displaystyle y^3=\left(3+\sqrt{a}\right)+3y\left((3+\sqrt{a})(3-\sqrt{a})\right)^{\frac{1}{3}}+(3-\sqrt{a})\)
\(\displaystyle y^3=\left(3+\sqrt{a}\right)+3y(9-a)^{\frac{1}{3}}+(3-\sqrt{a})\)
Rearrange the equation a bit and we get
\(\displaystyle y(y^2-3(9-a)^{\frac{1}{3}})=6\)
Since $y$ is an integer, we see that
\stackrel{\text{or}}{=}1(6)\stackrel{\text{or}}{=}2(3)\)
If $y=1$, then \(\displaystyle 1^2-3(9-a)^{\frac{1}{3}}=6\;\;\rightarrow a=\frac{368}{27}\).
If $y=6$, then \(\displaystyle 6^2-3(9-a)^{\frac{1}{3}}=6\;\;\rightarrow a=-\frac{42632}{27}\).
If $y=2$, then \(\displaystyle 2^2-3(9-a)^{\frac{1}{3}}=3\;\;\rightarrow a=\frac{242}{27}\).
If $y=3$, then \(\displaystyle 3^2-3(9-a)^{\frac{1}{3}}=2\;\;\rightarrow a=-\frac{100}{27}\).
Since $a>0$, the only possible values of $a$ in this problem are \(\displaystyle a=\frac{368}{27}\) and \(\displaystyle a=\frac{242}{27}\).
FAQ: Determine the positive numbers a
What is the value of "a" in positive numbers?
The value of "a" in positive numbers refers to any number that is greater than zero. It can be a whole number, a decimal, or a fraction, as long as it is a positive value.
How do you determine the positive numbers "a" in a set of numbers?
To determine the positive numbers "a" in a set of numbers, you need to look for any numbers that are greater than zero. These will be the positive numbers "a" in the set.
Can negative numbers be considered as positive numbers "a"?
No, negative numbers cannot be considered as positive numbers "a". Positive numbers are defined as numbers that are greater than zero, while negative numbers are less than zero. They are two distinct types of numbers.
What is the importance of determining positive numbers "a" in a scientific experiment?
Determining positive numbers "a" in a scientific experiment is important because it helps to accurately represent the data. Positive numbers are used to measure and quantify various factors in experiments, and they are crucial in drawing conclusions and making predictions based on the data.
How can we use positive numbers "a" to solve real-life problems?
Positive numbers "a" can be used to solve real-life problems in many ways. They can be used in financial calculations, such as budgeting and investments, and in scientific calculations, such as measuring distances and temperatures. Positive numbers are also essential in fields such as engineering, medicine, and economics.
