- #36
Purple_Dan
- 47
- 4
Other than that P&ID, I know relatively little about the equipment, I don't know lengths of pipes, diameters, volume or anything. I know that there's 0psi to the left of the isolation valve, 0psi below the control valve and the space inbetween can be between 50 and 23000psi.Chestermiller said:Are you trying to control the pressure drop at constant flow rate, the flow rate at constant pressure drop, or a combination of the two? If you're trying to control a combination of the two, then you need to quantify the interaction of the valve with the process equipment upstream of the valve (in terms of the fluid mechanics interactions). So far, aside from the control equipment, you haven't told us anything about the process equipment upstream.
Chet
If we take out all the unnecessary gumpf like gravity and pressure loss due to friction, what equation that will give me a prediction of the pressure? What variables will I need to know?
Thanks, I know it must be annoying not having all the data, but I don't have it either!
