MHB Determine the relative maximum and minimum on the graph
jaychay
Given that f is the function on (−∞, ∞) and the graph is the derivative of f
1.) Find the critical point on the graph ?
2.) Find the interval of the increasing function on the graph ?
3.) Find the interval of the decreasing function on the graph ?
4.) Find the point which is the absolute maximum on the graph ?
5.) Find the point which is the absolute minimum on the graph ?
5.) Find the point which is the absolute minimum on the graph ?View attachment 10704
Do the graph have the relative maximum and relative minimum ?
Let's add the graph of $\color{red}f(x)$ at an arbitrary level. That is, let's pick $\color{red}f(0)=0$.
And let's assume that $\color{red}f(x)$ is continuous at $x=10$.
\begin{tikzpicture}[
declare function={
df1(\x) = 2*cos(3/11*360)-2*cos((\x+1)/11*360);
df2(\x) = 1.25-5/16*(\x-13)^2;
f1(\x) = 2*cos(3/11*360)*\x-2*(sin((\x+1)/11*360) - sin(1/11*360))*11/(2*pi);
f2(\x) = 1.25*(\x-10)-5/16*((\x-13)^3 + 27)/3+f1(10);
%\draw[help lines] (-1,-3) grid (16,4);
\draw[-latex] (-1,0) -- (16,0);
\draw[-latex] (0,-3) -- (0,4);
\draw foreach \i in {1,...,15} { (\i,0.1) -- (\i,-0.1) node[below] {$\i$} };
% \draw foreach \i in {-2,...,2} { (0.1,\i) -- (-0.1,\i) node[ left ] {$\i$} };
\draw[domain=-1:10, variable=\x, thick, smooth] plot ({\x}, {df1(\x)}) (3, {df1(3)}) node[above left] {$f'(x)$};
\draw[domain=10:16, variable=\x, thick, smooth] plot ({\x}, {df2(\x)});
\filldraw[fill=black!5, thick] (10,{df1(10)}) circle (0.05) (10,{df2(10)}) circle (0.05);
\draw[domain=-1:10, variable=\x, red, thick, smooth] plot ({\x}, {f1(\x)}) (9, {f1(9)}) node[above right] {$f(x)$};;
\draw[domain=10:16, variable=\x, red, thick, smooth] plot ({\x}, {f2(\x)});
\end{tikzpicture}
Can we find those points and intervals now?
declare function={
\end{tikzpicture}
My answers for all of the question that I have done on my own is
  • 1.) 4.5,13
  • 2.) [0,4.5] , (10,13]
  • 3.) [4.5,10), [13, - ∞)
  • 4.) 4.5,13
  • 5.) 10
I want to check that I am doing it correct or not because I am not good at discontinuous graph
Can you please help me
Thank you in advice
  • 1.) 4.5,13
A critical point is a point in the domain of the function where the function is either not differentiable or the derivative is equal to zero.
That's not the case for x=4.5 or x=13 is it?
For which x-values is $f'(x)$ either zero or undefined?
A function is increasing if its derivative is greater than zero.
Where is $f'(x)$ greater than zero?
We can also look at the graph for $f(x)$ that I added.
Where is that graph increasing?
  • 4.) 4.5,13
  • 5.) 10
We have relative maxima and minima if $f'(x)=0$.
For which x-values is $f'(x)$ equal to zero?
Can we tell whether they correspond to maxima or minima?
Thank you very much
For original Zeta function, ζ(s)=1+1/2^s+1/3^s+1/4^s+... =1+e^(-slog2)+e^(-slog3)+e^(-slog4)+... , Re(s)>1 Riemann extended the Zeta function to the region where s≠1 using analytical extension. New Zeta function is in the form of contour integration, which appears simple but is actually more inconvenient to analyze than the original Zeta function. The original Zeta function already contains all the information about the distribution of prime numbers. So we only handle with original Zeta...
