Determine the term containing (Binomial Theorom)
  • Thread starter zaddyzad
  • Tags
    Term
Just do it.In summary, to find the term containing x^11 in the expansion (X^2 - 1/x)^10, one must factor out x^2 and then use algebra to determine that k must equal 3. The resulting term is -10C3 * x^-9.
zaddyzad
149
Determine the term containing... (Binomial Theorom)
Determine the term containing x^11 in the expansion (X^2 - 1/x)^10
T(k+1) = nC(k)*A^(n-k)*b^K
x^11 = 10Ck * (x^2)^(10-k)*(-X^-1)^k (taking out the (-) from the x^-1 b/c it don't matter)
x^11 = 10ck *X^(20-2k)(X^-k)
x^11/(X^20-3k) = 10ck
x^3k-9 = 10ck
Im stuck here.
Start by finding the coefficient of x1. That should give you a hint.
Its just 1. How does that help me ?
I don't think it is 1. [itex](x^2-\frac{1}{10})^{10}[/itex] contains only even powers of x, doesn't it? Forget the binomial theorem and just imagine what would happen if you start expanding it by hand.
Dick said:
I don't think it is 1. [itex](x^2-\frac{1}{x})^{10}[/itex] contains only even powers of x, doesn't it? Forget the binomial theorem and just imagine what would happen if you start expanding it by hand.
Mistake in my question.
Yeah. So you want [itex](x^2-\frac{1}{x})^{10}[/itex]. Factor out the x^2. So now you've got [itex]x^{20} (1-\frac{1}{x^3})^{10}[/itex]. What power do you want in the second factor?
Woah how did you get that? And I am looking for the term with X^11.
I used algebra. And to go back to your first post, which was pretty hard to read especially with the wrong problem statement, you want 20-3k=11. What's k? And the sign does matter.
Ok, so I'm looking for the term containing X^11. I tried using the formula T(k+1) = nC(k)*A^(n-k)*b^K. K is the variable of the formula.
n is 10.
I know the answer is 4 b/c it would be. 10c3(x^2)^7(-1/x)^3. However I don't care what the constant term is.
K is 3 making the term 4 according to the formula T(k+1) = nC(k)*A^(n-k)*b^K.
You were almost there is the first post. You want the exponent in (x^2)^(10-k)*(x^(-k)) to be 11. What's k?
Yes, k=3. Now think a little about the sign of the coefficient.
Yes its negative, however can't I just dismiss the coefficient since I'm only looking for its variable ?
Dick took a factor of x2 out of each of the 10 brackets. That turned each bracket into 1-1/x3, and combining the 10 factors outside produced x20.
Now imagine expanding the (1-1/x3)10. Suppose some term of that has the x power as 1/xk. You want the one which, when multiplied by x20, produces x11.
You threw away the sign and got 10C3 once you figured out k=3. But you shouldn't have thrown away the sign. It might be -10C3.
I like how this was solved with mental thinking. But how would you solve it using sheer algebra ?
You know, what you guys showed / helped me with is enough to solve similar questions. Thank you. I didnt know you can take x^2 out of (x^2 - 1/x)^10
You very nearly already did it in the first post. Add the insight that k must be 3, don't ignore the sign and try to write it out in a coherent way.
I can't have the insight that K must be 3 b/c that's what I was trying to solve for with algebra.
If x^(20-3k) is going to be x^11, k must be 3. Ok, forget 'insight'. You can work that out with algebra.
FAQ: Determine the term containing (Binomial Theorom)
What is the Binomial Theorem?
The Binomial Theorem is a mathematical theorem that allows for the expansion of a binomial expression raised to a positive integer power. It is often used to simplify complex algebraic expressions.
How is the Binomial Theorem used in real life?
The Binomial Theorem has many practical applications, such as in statistics, probability, and financial analysis. It is also used in engineering to model and analyze complex systems.
What is the formula for the Binomial Theorem?
The formula for the Binomial Theorem is (x + y)^n = ∑(n choose k) * x^(n-k) * y^k, where n is a positive integer and k ranges from 0 to n.
Why is the Binomial Theorem important?
The Binomial Theorem is important because it provides a systematic way to expand and simplify binomial expressions, making complex calculations more manageable. It also has many practical applications in various fields of science and mathematics.
Can you give an example of using the Binomial Theorem?
Sure, for example, if we have the expression (a + b)^3, we can use the Binomial Theorem to expand it as (a + b)^3 = a^3 + 3a^2b + 3ab^2 + b^3. This can be helpful in simplifying polynomial expressions and solving equations.
