Determine the time it take for the car and the truck to meet
  • Thread starter Thread starter Arden
    Car Time Truck
To determine when the car and truck meet, the car starts from rest 300m away and accelerates at 0.8m/s², while the truck moves towards it at a constant speed of 30m/s. Initial calculations suggested the car would take 27.38 seconds to reach a certain speed, while the truck would take 20 seconds to cover the distance, leading to confusion about their meeting time. The key misunderstanding arose from assuming the truck meets the car at 300m, rather than accounting for the truck's movement towards the car. The correct approach involves setting up equations that reflect the distances each vehicle travels, ultimately leading to the conclusion that they meet after approximately 8.94 seconds.
Arden
a car starts from rest at a point 300m from a truch that is moving at a constant rate of 30m/s toward the car. IF the car accelerates at .8m/s2, determine the time it take for the car and the truck to meet.
s=300
This is what I did
Car:
Vi = 0, a = .8
Vf^2=2as = Vf=21.9
Vf=at
21.9/.8 = 27.38
t=27.38sec
Truck:
S=(V/2)t
S=(15)t
300/15 = 20
t=20
They meet after (27.38 -20) = 7.38 seconds.
The answer given is 8.94seconds. Not sure what I am doing wrong?
You assumed the truck meets the car at 300 m. It doesn't, because the truck is moving towards the car.
You will need to set up your equation such as the car will cover a distance x, which will be the distance the truck meets the car, but the truck will cover a distance x+300.
dont you mean 300 - x
Depends on where you put your coordinate system, i put the origin on the car.
Thank you all for your help - Arden
  • · Replies 25 ·
  • · Replies 20 ·
