Determine the type of measurement by classification
  • Thread starter Thread starter Miristeri
    Voltage
The discussion focuses on determining the type of measurement, which is identified as direct - single. The user is seeking assistance with homework instructions that involve calculating errors based on provided voltage measurements and the multimeter's relative error of 4%. Specific tasks include calculating the error using the small sample method (Student distribution) and determining the instrumental error. The original question and relevant equations are missing, hindering progress. Clarification and guidance on these calculations are requested.
Miristeri
1) It is necessary to calculate the error using the small sample method (Student distribution).
2) Calculate the instrumental error
The equation is missing
I was only able to determine the type of measurement, it turns out to be direct - single. I can't find 1) and 2) of the homework instructions. I have the following data:Voltage:
U1, B = 15.05
U2, B = 15,06
U3, B = 15,05
Relative error of the multimeter
ΔU/U, % = 4
Help please
Miristeri said:
Homework Statement: 1) It is necessary to calculate the error using the small sample method (Student distribution).
Relevant Equations: The equation is missing
U1, B = 15.05
U2, B = 15,06
U3, B = 15,05
ΔU/U, % = 4
Help please
Please post the whole of the original question.
Likes Vanadium 50
Task 1. Suppose several measurements were made with a multimeterof voltage drops Ui on a resistor. The obtained values of the voltage drop Ui andthe relative error of the multimeter ΔU/U, determined bythe device data sheet, are shown in the table. Processing the results of the experiment.
1. Determine the type of measurement according to the classification and calculate the error.
1a. Calculate the error using the small sample method(Student distribution).
1b. Calculate the instrumental error
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
