MHB Determine the type of triangle PQR
  • Thread starter Thread starter anemone
    Triangle Type
The discussion centers on determining the type of triangle PQR given the equation $\cos P \cos Q + \sin P \sin Q \sin R = 1$. It is established that when angles P and Q are both $\frac{\pi}{4}$ and R is $\frac{\pi}{2}$, triangle PQR is a right-angled isosceles triangle. Participants confirm the correctness of this classification and share additional insights on the properties of such triangles. The conversation highlights the relationship between the angles and the specific triangle type. Overall, the analysis reinforces the conclusion that PQR is indeed a right-angled isosceles triangle.
anemone
MHB
POTW Director
Determine all triangles $PQR$ for which $\cos P \cos Q+\sin P \sin Q \sin R=1$.
Mathematics news on Phys.org
because of symmetry in P and Q let us assume P > Q
$\sin\, R $ cannot be 1 as $\sin\, R =1$ means
$\cos\, P \cos \, Q + \sin\, P \sin\, Q = 1$
or $\cos(P-Q)= 1$
so $R = (P-Q)= \dfrac{\pi}{2}$
which is impossible
$\sin\, R $ cannot be $\lt1$ as $\sin\, R \lt 1$ means
$\cos\, P \cos \, Q + \sin\, P \sin\, Q \gt1$
or $\cos(P-Q)\gt 1$ which is impossible
so no triangle
Thanks to Opalg's comment below I revisited the ans and realized that I had done the mistake that
$\cos(P-Q)= 1$
=> $(P-Q) = \dfrac{\pi}{2}$
it should be
$P-Q = 0$ giving $P=Q=\dfrac{\pi}{4}$ and $R = \dfrac{\pi}{2}$
or $\cos(P-Q)= 1$
which is impossible
so no triangle
[sp]What about $P = Q = \frac\pi4$, $R = \frac\pi2$?[/sp]
Thanks Opalg for your comment!
or $\cos(P-Q)= 1$
which is impossible
so no triangle
$\cos(P-Q)= 1$
it should be
Thanks for participating, kali! Your answer is correct, i.e. $PQR$ is a right-angled isosceles triangle.
The other brilliant solution that I want to share here is shown as follow:
Common sense tells us that
$\cos (P-Q)\le 1$
$\cos (P-Q)=\cos P \cos Q+\sin P \sin Q \le 1$---(*)
But we are told that $\cos P \cos Q=1-\sin P \sin Q\sin R$
Hence inequality (*) becomes
$\cos (P-Q)=1-\sin P \sin Q\sin R+\sin P \sin Q \le 1$
$\cos (P-Q)=1+\sin P \sin Q(1-\sin R) \le 1$
We can conclude by now that $\sin R=1$ and $\cos (P-Q)=1$, which means $R=90^{\circ}$, $P=Q=45^{\circ}$, or $PQR$ is a right-angled isosceles triangle.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
