Determine the unknown property of a perfect gas
In summary, the problem involves finding the value of R for a gas in a 3-L container with a pressure of 300kpa, temperature of 700 degrees celsius, and mass of .66 g. The equation PV= mRT is used to find the value of R, and the correct answer is 1.401 kj/kg.K.
thermo15378
a gas in 3-L container at a pressure of 300kpa and a temperature of 700 degrees celsius, and with a mass of .66 g.
pv=nrt
(300)(v)= (.00066 kg)(8.31)(191906 k)
= 3.51
im not sure what conversion needs to be done as the correct answer is found to be 1.401 kj/kg.K
pv=nrt
= 3.51
From the information given and the answer you posted, you are to use PV= mRT to get 'R' for the gas.
In your calculation you found 'V' as 3.51 when they already gave you V=3 L.
Related to Determine the unknown property of a perfect gas
1. What is a perfect gas?
A perfect gas is an idealized model of a gas that follows the gas laws, which describe the relationships between pressure, volume, and temperature.
2. How do you determine the unknown property of a perfect gas?
To determine the unknown property of a perfect gas, you can use one of the gas laws, such as Boyle's law, Charles's law, or Gay-Lussac's law. These laws can be rearranged to solve for the unknown property.
3. What are the assumptions made about a perfect gas?
The assumptions made about a perfect gas include that the gas particles have no volume, there are no intermolecular forces between particles, and the particles move in random, straight-line motion.
4. Can a real gas behave like a perfect gas?
In certain conditions, real gases can behave like a perfect gas. For example, at low pressures and high temperatures, the behavior of real gases can be approximated by the behavior of a perfect gas.
5. How is the ideal gas law used to determine the unknown property of a perfect gas?
The ideal gas law, PV = nRT, can be used to determine the unknown property of a perfect gas by plugging in known values for pressure, volume, and temperature, as well as the gas constant (R) and the number of moles (n). This equation can then be rearranged to solve for the unknown property.
  • Classical Physics
