Determine the value of expression (Calc-II)
In summary, the conversation discusses using the basic "Riemann sums" definition to find the integral of (1-x)^3 from 0 to 1. The person representing the expression uses the sum of (1-i/n)^3(1/n) with i going from 1 to infinity. The other person suggests using a limit as n goes to infinity and converting it to a definite integral. There is also a discussion about the usefulness of the integral in this specific problem. Ultimately, the value of the expression is determined to be 1/4.
alingy1
325
Please look picture.
I represented the expression with this integral :
I got 0, which makes no sense...
How should I proceed?
Correction:
I represented this using:
sum of (1-i/n)^3(1/n), i=1..infinity.
I expand it, and apply summation rules.
Problem solved?
It took me a moment to understand what you were doing! The problem you gave "Find the integral of (1- x)^3, from 0 to 1" can be done with a simple integration. But what you are doing is using the basic "Riemann sums" definition. Yes, if you divide the interval from 0 to 1 into n parts each part has length 1/n. And, at the right endpoint of the ith interval the function value is (1- i/n)^3 so the "area" of the thin rectangle there is (1- i/n)^3(1/n) and the entire area, and so the integral, is approximated by the sum.
No, i does not go from 1 to infinity- it goes from 1 to n and then, to get the actual integral, you take the limit as n goes to infinity.
You should have
[tex]\frac{1}{n}\sum_{i=1}^n \left( 1- 3\frac{i}{n}+ 3\frac{i^2}{n^2}- \frac{i^3}{n^3}\right)[/tex]
[tex]\frac{1}{n}\sum_{i= 1}^n 1- \frac{3}{n^2}\sum_{i= 1}^n i+ \frac{3}{n^3}\sum_{i= 1}^n i^2-\frac{1}{n^4}\sum_{i= 1}^n i^3[/tex]
alingy1 said:
Correction:
Problem solved?
I don't see how you get that. Do you see that it should be:
$$\lim_{n\rightarrow \infty} \frac{1}{n}\sum_{i=1}^{n-1} \left(\frac{i}{n}\right)^3$$
EDIT: Ok, your form is correct too. Now just convert it to a definite integral which is:
$$\int_0^1 (1-x)^3\,dx$$
There is no need to expand it.
Hmm... If I evaluate the integral, I get 1/4. But that answer is just right if I assume n goes to infinity. If am asked to determine the value of this expression, should I not use hallsofivy's last expression and the summation formulas to expand the i's into n?
I think my final answer should contain n's.
Ultimately, the integral is irrelevant in this problem?
Yes, use Halls's last expression.
Then use the summation formulas, the results of which will contain n, but not i .
What about the integral? Is it "useless" in this specific problem?
I think Halls has the correct interpretation of what's expected. Use the basic "Riemann sums" definition of the integral - taking the limit as n → ∞ .
To check your answer, find the value of the following integral in the usual way, by finding the anti-derivative of the integrand, etc.
##\displaystyle \int_0^1 (1-x)^3\,dx##​
Why would it be take the infinite sum? The question is determine the value of this expression without saying as n goes to infinity.
We can do that too but this is easily done using definite integrals. If you insist, here's how. I will be using the form I shown before because that doesn't requires expanding the terms as HallsOfIvy has done.
The sum under consideration is:
$$\frac{1}{n}\sum_{i=1}^{n-1} \left(\frac{i}{n}\right)^3=\frac{1}{n^4}\sum_{i=1}^{n-1}i^3$$
Since ##\displaystyle \sum_{i=1}^{n-1}i^3=\left(\frac{(n-1)n}{2}\right)^2##, we have the following limit:
$$\begin{aligned}
\lim_{n\rightarrow \infty} \frac{1}{n^4}\left(\frac{(n-1)n}{2}\right)^2 &= \lim_{n\rightarrow \infty} \frac{(n-1)^2}{4n^2}\\
&= \lim_{n\rightarrow \infty} \frac{1}{4}\left(1-\frac{1}{n}\right)^2 \\
&= \boxed{\dfrac{1}{4}}\\
\end{aligned}$$
I'm sorry. Perhaps I was not clear. My question is: the way you just did it supposes that n->infinity. But the original question is : determine the value of this expression in the picture. And in the picture, there is NO indication that n->infinity.
Do you understand what I'm trying to convey?
Ah ok, I thought this was another question related to Riemann sums. In that case, you leave it till the following step:
$$\frac{1}{4}\left(1-\frac{1}{n}\right)^2$$
I hope your issue is addressed now. :)
Excellent! This forum is filled of hardworking people!
FAQ: Determine the value of expression (Calc-II)
What is the purpose of determining the value of an expression in Calc-II?
The purpose of determining the value of an expression in Calc-II is to find the numerical result of the mathematical equation. This is important in order to solve more complex problems and make calculations in various fields such as engineering, physics, and economics.
How do you determine the value of an expression in Calc-II?
To determine the value of an expression in Calc-II, you need to follow the order of operations (PEMDAS) and use algebraic techniques such as factoring, simplifying, and substituting values for variables. You may also need to use trigonometric functions, logarithms, or exponentials depending on the type of expression.
What are some common mistakes to avoid when determining the value of an expression in Calc-II?
Common mistakes to avoid when determining the value of an expression in Calc-II include not following the proper order of operations, making careless errors in arithmetic, and forgetting to simplify the expression before calculating the value. It is also important to double-check your work and use parentheses correctly to avoid errors.
Can you use a calculator to determine the value of an expression in Calc-II?
Yes, you can use a calculator to determine the value of an expression in Calc-II. However, it is important to note that calculators may not always give exact answers and may round off numbers, which could result in small differences in the final answer. It is always recommended to also solve the expression by hand to verify the accuracy of the calculator's result.
What are some real-world applications of determining the value of an expression in Calc-II?
Determining the value of an expression in Calc-II has many real-world applications, such as calculating the trajectory of a projectile in physics, predicting population growth in economics, and optimizing the design of a bridge in engineering. It is also useful in everyday tasks such as budgeting and calculating interest rates in finance.
