Determine whether it's an inner product on R^3
In summary, the homework statement is trying to determine if it's an inner product on R3. If it's not, then the axiom that does not hold is axiom 4 which states that <v, v > = v1v1 + v3v3. However, this does not hold because there are only 2 components in that equation.
sam0617
Let u = (u1, u2, u3)
and v = (v1, v2, v3)
Determine if it's an inner product on R3.
If it's not, list the axiom that do not hold.
the 4 axioms to determine if it's an inner product are
(all letters representing vectors)
1. <u,v> = <v,u>
2. <u+v, w> = <u, w> + <v,w>
3. <ku, v> = k<u,v>
4. <v,v> ≥ 0 and < v,v> = 0 if and only if v = 0
So <u, v> is defined as
u1v1 + u3v3
I'll skip the ones that did work and show axiom 4 which did not hold but I'm confused as to why this doesn't hold. I have a guess but have to make sure that I'm thinking correctly.
Axiom 4 does not hold:
= v12 + v32 ≥ 0
and
<0, 0> = (0)(0) + (0)(0) = 0
now to check the other way:
if <v, v > = 0
implies that since
v12 = 0 => v1 = 0
v32 = 0 => v3 = 0
then it goes to say it's not an inner product on R3. Am I correct to say it's not an inner product on R3 because there are only 2 components for axiom 4? and not 3? (i.e. no v2 showing anywhere)
Thank you for any help. Will be much appreciated.
1. <u,v> = <v,u>
3. <ku, v> = k<u,v>
u1v1 + u3v3
Okay, I was wondering if you were going to mention that!:-p
= v12 + v32 ≥ 0
and
if <v, v > = 0
implies that since
v12 = 0 => v1 = 0
v32 = 0 => v3 = 0
Specifically, because there is no "v2", If u= (0, 1, 0) u is not 0 but <u, u>= 0, contradicting that last law.
Oh okay, that makes sense.
So just to clarify, because if <v, v > = 0 if and only if v = the zero vector
but we don't know v2 due to how <u, v > is defined so that means v2 could be a non-zero number.
Correct me if my logic is wrong.
Thank you again, HallsofIvy.
FAQ: Determine whether it's an inner product on R^3
What is an inner product on R^3?
An inner product on R^3 is a mathematical operation that takes two vectors in R^3 and produces a scalar value. It is used to measure the angle between two vectors and the length of a vector.
How do you determine if a function is an inner product on R^3?
To determine if a function is an inner product on R^3, you must check if it satisfies the three properties of an inner product: linearity in the first argument, conjugate symmetry, and positive definiteness.
What does it mean for a function to be linear in the first argument?
A function is linear in the first argument if it follows the property of distributivity, where c(u+v) = cu + cv, for any constant c and vectors u and v.
What is conjugate symmetry in regards to inner products on R^3?
Conjugate symmetry means that the inner product of two vectors, u and v, is equal to the complex conjugate of the inner product of v and u. In other words, if u = (u1, u2, u3) and v = (v1, v2, v3), then
the inner product of u and v is equal to the complex conjugate of the inner product of v and u.
What does positive definiteness mean for an inner product on R^3?
Positive definiteness means that the inner product of a vector with itself is always greater than 0. In other words, the inner product of a vector with itself cannot be 0 or a negative number.
