Determine whether ## S[y] ## has a maximum or a minimum
In summary, to determine whether the function S[y] has a maximum or a minimum, one must analyze its critical points by calculating the first and second derivatives. The first derivative helps identify critical points where the slope is zero, while the second derivative indicates the concavity of the function at these points. If the second derivative is positive at a critical point, S[y] has a local minimum; if negative, it has a local maximum. Additionally, evaluating the function's behavior at the endpoints or using the first derivative test can further clarify the nature of the extrema.
Math100
807
223
Let ## a, b ## and ## w ## be constants, with ## w\neq 0 ##.
a) Show that the Euler-Lagrange equation for the functional ## S[y]=\int_{1}^{2}(y'^2+w^2y^2+2y(a \sin(wx)+b \sinh(wx)))dx, y(1)=0, y(2)=1 ##, is ## y''-w^2y=a \sin(wx)+b \sinh(wx), y(1)=0, y(2)=1 ##.
b) Solve this equation to show that the stationary path is ## y=\alpha\sinh(w(x-1))+\beta\sinh(w(x-2))-\frac{a \sin(wx)}{2w^2}+\frac{bx \cosh(wx)}{2w} ##, where ## \alpha=\frac{1}{\sinh(w)}[1+\frac{a \sin(2w)}{2w^2}-\frac{b \cosh(2w)}{2}], \beta=\frac{1}{\sinh(w)}[\frac{b\cosh(w)}{2w}-\frac{a \sin(w)}{2w^2}] ##.
c) Determine whether ## S[y] ## has a maximum or a minimum on this stationary path, and whether it is global or local.
Euler-Lagrange equation:
For the functional ## S[y]=\int_{a}^{b}F(x, y, y')dx, y(a)=A, y(b)=B ##, the Euler-Lagrange equation is ## \frac{d}{dx}(\frac{\partial F}{\partial y'})-\frac{\partial F}{\partial y}=0, y(a)=A, y(b)=B ##.
a) The Euler-Lagrange equation is of the form ## \frac{d}{dx}(\frac{\partial F}{\partial y'})-\frac{\partial F}{\partial y}=0, y(a)=A, y(b)=B ##.
Let ## F(x, y, y')=(y'^2+w^2y^2+2y(a \sin(wx)+b \sinh(wx))) ##.
Then ## \frac{\partial F}{\partial y'}=2y' ## and ## \frac{\partial F}{\partial y}=2w^2y+2(a \sin(wx)+b \sinh(wx)) ##.
Note that ## \frac{d}{dx}(\frac{\partial F}{\partial y'})-\frac{\partial F}{\partial y}=0\implies 2\frac{d^2y}{dx^2}-2w^2y-2(a \sin(wx)+b \sinh(wx))=0 ##, so we have ## \frac{d^2y}{dx^2}-w^2y=a \sin(wx)+b \sinh(wx) ##.
Therefore, the Euler-Lagrange equation is ## y''-w^2y=a \sin(wx)+b \sinh(wx), y(1)=0, y(2)=1 ##.
b) Consider the differential equation ## y''-w^2y=a \sin(wx)+b \sinh(wx), y(1)=0, y(2)=1 ##.
The characteristic equation is ## r^2-w^2=0\implies y_{h}=c_{1}e^{x}+c_{2}e^{-x} ##.
Let the particular solution be of the form ## y_{p}=A \sin(wx)+Bx \cosh(wx) ##.
Then ## y_{p}'=Aw \cos(wx)+Bwx \sinh(wx)+B \cosh(wx) ## and ## y_{p}''=-Aw^2 \sin(wx)+Bw^2x \cosh(wx)+Bw \sinh(wx)+Bw \sinh(wx) ##.
Substituting ## y_{p}'', y_{p} ## into our original differential equation produces:
## -Aw^2 \sin(wx)+Bw^2x \cosh(wx)+Bw \sinh(wx)+Bw \sinh(wx)-w^2[A \sin(wx)+Bx \cosh(wx)]=a \sin(wx)+b \sinh(wx) ##.
Now we have ## -2Aw^2 \sin(wx)=a \sin(wx) ## and ## 2Bw \sinh(wx)=b \sinh(wx) ##, so ## A=\frac{a}{-2w^2}, B=\frac{b}{2w} ##.
Thus ## y=c_{1}e^{x}+c_{2}e^{-x}-\frac{a \sin(wx)}{2w^2}+\frac{bx \cosh(wx)}{2w} ##.
By our boundary conditions, we have ## y(1)=0\implies 0=c_{1}e+c_{2}e\implies c_{1}=-c_{2} ## and ## y(2)=1\implies 1=c_{1}e^{2}+c_{2}e^{-2}-\frac{a \sin(2w)}{2w^2}+\frac{2b \cosh(2w)}{2w} ##.
Observe that ## c_{2}(-e^{2}+e^{-2})-\frac{a \sin(2w)}{2w^2}+\frac{b(e^{2w}+e^{-2w})}{2w}=1 ##.
From here, I cannot see why does the stationary path is ## y=\alpha\sinh(w(x-1))+\beta\sinh(w(x-2))-\frac{a \sin(wx)}{2w^2}+\frac{bx\cosh(wx)}{2w} ##, even with the given forms of both ## \alpha ## and ## \beta ##. I know that the hyperbolic functions of ## \sinh(x), \cosh(x) ## are ## \sinh(x)=\frac{e^{x}-e^{-x}}{2} ## and ## \cosh(x)=\frac{e^{x}+e^{-x}}{2} ## but I still don't see how this gives our desired answer.
c) Does anyone know how to find the second variation? If the second variation is positive, then the given functional ## S[y] ## has a minimum on the stationary path and if the second variation is negative, then the given functional ## S[y] ## has a maximum on the stationary path.
On bounded domains, [itex]\cosh wx[/itex] and [itex]\sinh wx[/itex] are linearly independent solutions of [itex]y'' - w^2 y = 0[/itex] which are easier to work with than [itex]e^{\pm wx}[/itex]. You should know the basic identities [tex]\begin{split}
\sinh (u \pm v) &\equiv \sinh u \cosh v \pm \sinh v \cosh u \\
\cosh (u \pm v) &\equiv \cosh u \cosh v \mp \sinh u \sinh v \end{split}
[/tex] The point here is that [itex]\sinh (w(x- 1))[/itex] and [itex]\sinh (w(x-2))[/itex] are linearly independent solutions of [itex]y'' - w^2 y = 0[/itex] which make it easy to apply boundary conditions on [itex]y(1)[/itex] and [itex]y(2)[/itex], since if [tex]
y(x) = \alpha \sinh (w(x - 1)) + \beta \sinh (w(x - 2)) + y_p(x)[/tex] then [tex]\begin{split}
y(1) &= - \beta \sinh w + y_p(1) \\
y(2) &= \alpha \sinh w + y_p(2). \end{split}[/tex]
Likes Math100
You have jumped straight to the E-L formula. The text does not want you to do that; that is why it is asking questions which cannot be answered that way, but which are easily answered if you derive the E-L equation from the Gateaux derivative for the specific case, and in the course of so doing calculate [itex]S[y + \epsilon h] - S[y].[/itex]
Try that now. Write [itex]S[y] = \int_1^2 y'^2 + w^2y^2 + 2yf(x)\,dx.[/itex] Then calculate [itex]S[y + \epsilon h] - S[y][/itex], remembering to integrate [itex]h'y' = (y'h)' - y''h[/itex] by parts. You know that the boundary term disappears because [itex]h[/itex] must satisfy [itex]h(1) = h(2) = 0[/itex], and that on the stationarry path [itex]-y'' + w^2 y + f(x) = 0[/itex]. What's left? Is it necessarily positive or negative?
I didn't know about this before. It's been several years since I took the course "Ordinary Differential Equations" and since then, I never worked with hyperbolic functions so these are all new to me. But thank you for telling me all these identities.
I got the desired answer for part b). However, for part c), I found out that ## S[y+\epsilon h]-S[y]=\int_{1}^{2}(2\epsilon y'h'+\epsilon^2h'^2-2\epsilon hw^2y-\epsilon^2w^2h^2+2\epsilon h''y+2\epsilon hy''+2\epsilon^2hh'')dx ## and I factored out the ##\epsilon##, to get ## \epsilon\int_{1}^{2}(2y'h'+\epsilon h'^2-2w^2yh-\epsilon w^2h^2+2yh''+2y''h+2\epsilon hh'')dx ##. From here, how to integrate each term inside this integrand? I know that I have to use the method of integration by parts, but I don't know what to get after I integrate. For example, the first term I got is ## \int_{1}^{2}2y'h'dx=[y'h]_{1}^{2}-\int_{1}^{2}2y''hdx=y'h(2)-y'h(1)-[2y''h(2)-2y''h(1)]=0 ## since ## h(1)=h(2)=0 ## but is this correct?
If [itex]y_c[/itex] is the stationary path, then any other path [itex]y[/itex] can be expressed as [itex]y = y_c + (y -y_c) = y_c + h[/itex] where [itex]h(1) = h(2) = 0[/itex]. Then [tex]\begin{split}
S[y] &= S[y_c + h] \\
&= \int_1^2 (y_c' + h')^2 + w^2(y_c + h)^2 + 2(y_c + h)f(x)\,dx \\
&= S[y_c] + \int_1^2 2y_c'h' + h'^2 + 2w^2 y_ch + w^2h^2 + 2h f(x)\,dx\\
&= S[y_c] + \underbrace{[2hy_c']_1^2}_{\mbox{$= 0$}} + \int_1^2 -2y_c''h +h'^2 + 2w^2 y_ch + w^2h^2 + 2h f(x)\,dx \\
&= S[y_c] + \int_1^2 2h (-y_c'' + w^2 y_c + f(x)) + h'^2 + w^2h^2\,dx.\end{split}
[/tex] We already know that [itex]-y''_c + w^2 y_c + f(x) = 0[/itex], so we are left with [tex]
S[y] = S[y_c] + \int_1^2 h'^2 + w^2 h^2\,dx.[/tex] What can we conclude about the sign of the integand for arbitrary [itex]h[/itex]? What follows from this?
Likes Math100 and fresh_42
I got ## \int_{1}^{2}(h'^2+w^2h^2)dx=(h(2))^2-(h(1))^2+w^2(\frac{(h(2))^3}{3}-\frac{(h(1))^3}{3})=0 ## but is this correct?
No this is not correct.
@pasmith asked about the sign of the integrand (what's inside the integral), i.e. ##h'^{2}+w^2 h^2##. What is the sign of that expression, and what can you conclude about its integral?
The sign of the integrand is obviously positive, but what can we conclude about this integral then?
The integral can be defined as the limit of a finite Riemann sum. If you sum a sequence of all positive numbers, what sign will that sum have? What can you conclude about the sign of the limiting integral?
That sum will have a positive sign. And the sign of the limiting integral is also positive.
OK, so that means:$$\int_{1}^{2}\left(h'^{2}+w^{2}h^{2}\right)\,dx\geq0$$(where I've used a ##\geq## sign to include the edge case ##h\equiv0##). You can therefore rewrite the last equation in post #6 by @pasmith to read:$$S[y]-S[y_{c}]=\int_{1}^{2}\left(h'^{2}+w^{2}h^{2}\right)\,dx\geq0$$or:$$S[y]\geq S[y_{c}]$$To answer part c) of your OP, what do you finally conclude about ##S[y_{c}]## in comparison to all other possible values of the action ##S##?
That the stationary path ## y ## is a local maximum.
The problem is asking about the the stationary action (i.e., the value of ##S[y_c]##), not anything about the stationary path ##y_c## itself: "c) Determine whether ##S[y]## has a maximum or a minimum on this stationary path, and whether it is global or local." Is it's value greater or lesser than all other action values ##S[y]##? And is this inequality true only for paths sufficiently near ##y_c## (i.e., locally) or for all paths that deviate from the stationary path, no matter how far (i.e., globally)?
Its value is less than all other action values ##S[y]##. But how do we know if this inequality is true only for paths sufficiently near ##y_c## or for all paths that deviate from the stationary path, no matter how far?
In this case, the expression [tex]
S[y_c + \epsilon h] = S[y_c] + \epsilon^2 \int_1^2 w^2h^2 + h'^2\,dx[/tex] is exact; there are no terms of order [itex]\epsilon^3[/itex] or higher which we neglected in deriving it. What can you conclude?
So ## S[y_{c}+\epsilon h]-S[y_{c}]=\epsilon^2\int_{1}^{2}(w^2h^2+h'^2)dx ##
## S[y_{c}+\epsilon h]-S[y_{c}]=\epsilon^2\int_{1}^{2}(w^2h^2+h'^2)dx\geq 0 ##
## S[y_{c}+\epsilon h]\geq S[y_{c}] ##
How is this different from the one we obtained above? I still don't know what we can conclude about this result.
To derive this inequality, were you forced to put any limitation at all on ##\epsilon## (like ##\epsilon \ll 1##)? If not, then ##\epsilon## is completely arbitrary, which says that the inequality remain true, even when the difference between ##y## and ##y_c## is arbitrarily large. What do you conclude?
Likes Math100
That the value of ## S[y_{c}] ## has a global minimum.
Likes renormalize
FAQ: Determine whether ## S[y] ## has a maximum or a minimum
What is the first step in determining whether ## S[y] ## has a maximum or a minimum?
The first step is to find the first variation of the functional ## S[y] ##, which involves calculating the functional derivative and setting it equal to zero. This gives the Euler-Lagrange equation, which must be satisfied by the function ## y(x) ## that extremizes the functional.
How do you find the second variation of the functional ## S[y] ##?
The second variation of the functional ## S[y] ## is found by taking the second derivative of ## S[y] ## with respect to ## y ## and evaluating it at the extremal function ## y(x) ##. This involves computing the second functional derivative and analyzing its sign.
What role does the second variation play in determining a maximum or minimum?
The second variation determines the nature of the extremum. If the second variation is positive for all permissible variations of ## y(x) ##, then ## S[y] ## has a local minimum. If it is negative for all permissible variations, then ## S[y] ## has a local maximum. If it changes sign, the extremum is a saddle point.
Can boundary conditions affect whether ## S[y] ## has a maximum or minimum?
Yes, boundary conditions can significantly affect the extremum. They must be taken into account when solving the Euler-Lagrange equation and when evaluating the second variation. The correct application of boundary conditions ensures that the variations considered are permissible.
What are common methods to solve the Euler-Lagrange equation?
Common methods to solve the Euler-Lagrange equation include direct integration, using known solutions of similar problems, applying symmetry considerations, and employing numerical methods for more complex or non-analytical cases.
