Determine whether the following series converes or diverges and find the sum
  • Thread starter kuczmama
  • Tags
    Series Sum
In summary: Yes you can break it up like that. It makes two separate problems. What about my other suggestion in red above?this is probably a dumb question, but how do I factor something out if it is a sequence.
kuczmama
infinity
Ʃ(2n+3n)/(4n+1)
n=0
We learned the integral test. The p-series. The nth term test.
I figured out that the terms are positive and that they approach 0. the first couple of terms are (2/4)+ 5/16+13/64+35/256+...
I think I can use the integral test, but that only tells me whether or not it converges. I think that it does. However, I don't know how to find its sum. If you guys could help me out I would really appreciate it.
Think about geometric series.
I know that a geometric series is like a+ar+ar2+ar3+...arn, but I don't know how to re-write this in that form
Break it up into two problems and factor a 4 out of the denominator.
do you mean break it up into two integrals? or would it be like
Ʃ2n/4n+1 +Ʃ 3n/4n+1
Can you break it up like that?
I can't find a common r value. I don't think it is a geometric series. So I am pretty lost still.
Ʃ2n/4n+1 +Ʃ 3n/4n+1
this is probably a dumb question, but how do I factor something out if it is a sequence. I really don't know how to factor a 4 out of the denominator. like would I multiply the problem by 1/4
[tex]\frac 1 {4^{n+1}} = \frac 1 4\cdot\frac 1 {4^n}[/tex]
Ohh ok. Thank you so much. I just figured it out. I now know that the sum is (3/2). I didnt know you could factor it out like that. that helps so much.
FAQ: Determine whether the following series converes or diverges and find the sum
What does it mean for a series to converge or diverge?
When a series converges, it means that the sum of all its terms approaches a finite value as the number of terms increases. On the other hand, when a series diverges, it means that the sum of its terms either approaches infinity or does not approach any finite value.
How can I determine whether a series converges or diverges?
There are various tests that can be used to determine the convergence or divergence of a series, such as the comparison test, ratio test, and integral test. These tests involve analyzing the properties of the series' terms and the behavior of the series as the number of terms increases.
What is the sum of a convergent series?
The sum of a convergent series is the finite value that the series approaches as the number of terms increases. This sum can be calculated by adding up all the terms of the series or by using other mathematical techniques such as partial sums.
Can a series converge and diverge at the same time?
No, a series cannot converge and diverge at the same time. A series can either converge or diverge, depending on the behavior of its terms. It is not possible for a series to approach a finite value and infinity at the same time.
What factors can affect the convergence or divergence of a series?
The properties of the terms in a series, such as their size and behavior, can affect its convergence or divergence. Additionally, the order of the terms and the number of terms in the series can also play a role in determining its convergence or divergence.
