Ry122
- 565
- 2
How do i determine if ((x-4)^(1/2))+3=y is a function? How do I determine the domain and range?
sprint said:for every number you plug into X, there will be a number Y that would result.
so yes, it is a function.
domain is all positive numbers since you can't take the square root of a negative number.
well you can but I am assuming your teacher doesn't grade at that kind of level.
and again I am making assumptions because of the nature of your question.
danago said:What about x=1? 1 is a positive number, and it still results in taking the square root of a negative number.
An equation is a mathematical statement that shows the relationship between two or more quantities. It typically consists of variables, constants, and mathematical operations.
A function is a special type of equation where each input (or independent variable) has exactly one output (or dependent variable). In other words, for every x-value, there is only one corresponding y-value.
To determine if an equation is a function, you can use the vertical line test. If a vertical line intersects the graph of the equation at only one point, then the equation is a function. If the vertical line intersects the graph at more than one point, then the equation is not a function.
No, by definition, a function can only have one output for each input. If there are multiple outputs for a given input, then the equation is not a function.
An equation is a mathematical statement that shows the relationship between two or more quantities, while a function is a special type of equation where each input has exactly one output. All functions are equations, but not all equations are functions.
