Determing The Chemical Formula of a Hydrate
In summary, when heated in air, copper (II) sulfate hydrate loses water molecules and transforms into an anhydrous crystal. The mass of water driven off can be calculated by subtracting the mass of anhydrous copper sulfate from the mass of the hydrate. The number of moles of water and CuSO4 present can be calculated using their respective molar masses. To determine the ratio of moles of water to moles of CuSO4, simply divide the two calculated values.
jess4
When copper (II) sulfate hydrate, a blue crystalline solid containing embedded water molecules (called a hydrate), is heated in air, it loses the water molecules and the blue solid is transformed to a white anyhydrous (no water) crystal known as copper (II) sulfate.
CuSO4 .x H2O +heat --> CuSO4 (s) + H2O (g)Observations: Mass of copper (II) sulfate hydrate = 0.1534g
Mass of anyhydrous copper (II) sulfate = 0.0980g
1a) Calculate mass of H2O that was driven off.
b) Calculate the number of moles of water present.
c) Calculate the number of moles of CuSO4 present.
My attempt to answer these questions:
1a) Since anhydrous copper sulfate has no water the mass of H2O driven off is 0.1534g - 0.0980g =0.0554g
b) n = m/M n= 0.0554/18.02 therefore, n= 3.07 x10 to the power of -3.
c) Mcuso4 = 159.62g/mol so, n=m/M n= 0.0980g/159.62g/mol which = 6.13 x10 to the power of -4
So far so good (that is, I have not checked the numbers, just the general idea).
What is the ratio?
The numbers just don't look right for some reason...
No ratio given, that's a whole new question "Determine the ratio of moles of water to moles of CuSO4" that i have yet to attempt. If my answers are right then i can move on.
Come on, "whole new question" means just divide two numbers you got so far.
I would like to commend the student for their attempt to answer the questions and for showing their understanding of the concept of a hydrate. However, I would like to provide some additional information and clarify some points.
Firstly, the chemical formula for copper (II) sulfate hydrate is actually CuSO4 · xH2O, where x represents the number of water molecules attached to each copper (II) sulfate molecule. This number can vary depending on the conditions and the specific hydrate being studied.
Secondly, in order to determine the chemical formula of a hydrate, it is important to conduct multiple trials and calculate the average values for the mass of the hydrate and the anhydrous compound. This will help to reduce any errors and provide a more accurate result.
In addition, it is important to use a balance with high precision (at least 3 decimal places) when measuring the masses, and to record all measurements and calculations with the correct number of significant figures.
To determine the mass of water driven off (question 1a), the correct calculation should be: mass of water = mass of hydrate - mass of anhydrous compound = 0.1534g - 0.0980g = 0.0554g.
For question 1b, the number of moles of water present can be calculated using the molar mass of water (18.02g/mol) and the mass of water calculated above: n = m/M = 0.0554g/18.02g/mol = 0.00308 mol.
Similarly, for question 1c, the number of moles of CuSO4 present can be calculated using the molar mass of CuSO4 (159.62g/mol) and the mass of anhydrous compound (0.0980g): n = m/M = 0.0980g/159.62g/mol = 0.000614 mol.
Finally, it is important to note that the chemical formula of a hydrate can also be determined using other methods, such as gravimetric analysis or titration. These methods may provide more accurate results and can be used to confirm the formula obtained from the mass measurements.
In conclusion, determining the chemical formula of a hydrate is an important aspect of chemistry, and it requires careful measurement and calculation to obtain accurate results. By following the correct procedures and
Related to Determing The Chemical Formula of a Hydrate
1. What is a hydrate?
A hydrate is a compound that contains water molecules within its crystal structure. It is formed when a salt or other compound is combined with water in a specific ratio.
2. How do you determine the chemical formula of a hydrate?
The chemical formula of a hydrate can be determined by conducting experiments to determine the mass of the hydrate and the mass of the anhydrous compound (without water). The ratio of these two masses can then be used to determine the number of water molecules in the hydrate and the chemical formula.
3. What is the importance of determining the chemical formula of a hydrate?
Determining the chemical formula of a hydrate is important as it allows us to understand the structure and composition of the compound. This information can then be used to predict the properties and behavior of the compound and its uses in various industries.
4. What are some common methods used to determine the chemical formula of a hydrate?
Some common methods used to determine the chemical formula of a hydrate include heating the hydrate to remove the water, titration with a known amount of acid or base, and conducting experiments to determine the ratio of water to anhydrous compound.
5. Can the chemical formula of a hydrate change?
Yes, the chemical formula of a hydrate can change if the conditions under which it was formed or stored are altered. For example, if the temperature or pressure changes, the water molecules within the crystal structure may be released, resulting in a change in the chemical formula of the hydrate.
108K
21K
