Determining a subspace of polynomials with degree 3
In summary: I don't know what it is. You seem to be doing everything correctly.In summary, the conversation discusses determining which of the given polynomials (a0+a1x+a2x^2+a3x^3) are subspaces of P3, with the conditions that the zero vector must be included, the sum of two vectors must be in the subspace, and the scalar multiple of a vector must also be in the subspace. The polynomials that fulfill these conditions are a) where a0=0, b) where a0+a1+a2+a3=0, c) where a0, a1, a2, and a3 are integers, and d) where a0 and a1 are
cuttlefish
Determine which of the following are subspaces of P3:
a) all polynomials a0+a1x+a2x^2+a3x^3 where a0=0
b) all polynomials a0+a1x+a2x^2+a3x^3 where a0+a1+a2+a3=0
c) all polynomials a0+a1x+a2x^2+a3x^3 for which a0, a1, a2, a3 are integers
d) all polynomials of the form a0+a1x where a0 and a1 are real numbers
in order for U={v in Z: v=(a0+a1x+a2x^2+a3x^3)} to be a subspace, these polynomials should fulfil:
1) 0 vector included in U
2) x in U, y in U, x+y also in U
3) c (some constant) in U, x in U, c*x also in U
sorry for writing "in", I'm not sure how to get the sign and I'm not even sure what it's called in English. In Swedish you say "belongs to".
a) I'm pretty sure that this is fulfils all of the conditions. Because a0=0, the zero vector is included when x=0 then a0+a1*0+a2*0+a3*0=0 is true.
b) Here is where I begin to get a little confused. My problem is mainly with the concept of the null vector. My question is whether "0 vector included in U) means that the set of polynomials U somewhere contains a polynomial that, for some value of x, gives the value 0, or whether it means that U contains a polynomial equal to zero specifically for x=0. The way I've solved this problem so far is to say:
a0+a1x+a2x^2+a3x^3=0 occurs when x=1 since we then get a0+a1+a2+a3=0 in accordance with the restriction imposed in the problem.
But is this the correct way to think of this problem?
c) This is where my above reasoning begins to confuse me. If I have a0+a1x+a2x^2+a3x^3, all of whose coefficients are integers, one could say that a0 was the integer 0 and then for x=0 the null vector would be realized. But is it important that the coefficients don't receive a specific value like that, that they be just general constants?
d) I'm not even sure how to go about this one.
What's really need is for someone to point out what I should be checking. I know it should be obvious from the conditions of a subspace but I guess I'm just not really sure what they mean.
What you wrote is perfectly correct. Either "(is) in" or "belongs to" are good. For the symbols, use "[ itex ]x\in U[ /itex ]" without the spaces: [itex]x\in U[/itex]. (Double click on that formula, or any formula, to see the code used.)
The "zero vector", when your vectors are functions, is the function the is identically 0, 0 for all x. The "zero vector" is in this set because you can take a1= a2= a3= 0 which still satisfies "a0= 0".
Neither! As I said above, it means the polynomial that is 0 for all x. That requires that all coefficients be 0. Does such a polynomial satisfy "a0+ a1+ a2+ a3= 0"?
No, it is not. The "0 vector" is the vector \(\displaystyle 0+ 0x+ 0x^2+ 0x^3\) and that satisfies the condition.
Again, the question is whether the specific 0 polynomial, [itex]0+ 0x+ 0x^2+ 0x^3[/itex] satisfies the conditions- which it does: 0 is an integer.
You should also find that [itex](a0+ a1x+ a2x^2+ a3x^3)+ (b0+ b1x+ b2x^2+ b3x^3)[/itex], the sum of sum of two such vectors, is [itex](a0+ b0)+ (a1+ b1)x+ (a2+ b2)x^2+ (a3+ b3)x^3[/itex] and the sum of two integers is an integer.
However, what about the scalar product: [itex](1/2)(1+ x+ x^2+ x^3)[/itex]?
Exactly the same way. Now the 0 "vectors" is 0+ 0x. Is 0 a real number?
What about (a+ bx)+ (c+ dx)= (a+ c)+ (b+d)x where a, b, c, d are real numbers? Are a+ c and b+ d real numbers? What about a(b+ cx)= ab+ acx where a, b, and c are real numbers. Are ab and ac real numbers?
You only difficulty seems to be understanding exactly what the "zero vector" is. In general, it is the "additive identity"- that is, 0 is defined by the property that 0+ v= v for any vector v. For function spacex, just being equal to 0 at some values of x is not enough. In order that (O+ f)(x)= f(x) for all x (I am using "O" for the 0 function), we must have O(x)+ f(x)= f(x) so that O(x)= 0 for all x.
Thanks! That was exactly what I was hoping to get.
FAQ: Determining a subspace of polynomials with degree 3
What is a subspace of polynomials with degree 3?
A subspace of polynomials with degree 3 is a set of polynomials where each polynomial has a degree of 3 or less. This means that the highest power of the variable in each polynomial is 3, and there may also be lower degree terms.
How do you determine if a set of polynomials is a subspace?
In order for a set of polynomials to be a subspace, it must meet three criteria: it must contain the zero polynomial, it must be closed under addition, and it must be closed under scalar multiplication. This means that any linear combination of polynomials from the set must also be in the set, and multiplying a polynomial by a constant must also result in a polynomial in the set.
What is the dimension of a subspace of polynomials with degree 3?
The dimension of a subspace of polynomials with degree 3 is 4. This is because there are 4 basis polynomials that can span any polynomial of degree 3 or less: 1, x, x^2, and x^3. Any polynomial in the subspace can be written as a linear combination of these basis polynomials.
How do you find a basis for a subspace of polynomials with degree 3?
To find a basis for a subspace of polynomials with degree 3, you can use the method of Gaussian elimination. Write the set of polynomials as a matrix, and then use row operations to reduce the matrix to row-echelon form. The resulting rows will correspond to the basis polynomials.
What is the difference between a subspace of polynomials with degree 3 and a subspace of polynomials with degree 2?
The difference between these two subspaces is the degree of the polynomials that they contain. A subspace of polynomials with degree 3 contains polynomials with a maximum degree of 3, while a subspace of polynomials with degree 2 contains polynomials with a maximum degree of 2. This means that the basis for each subspace will be different, and the dimension will also be different (4 for degree 3 and 3 for degree 2).
