Determining best method for volumes?
In summary, when determining which method to use for solving volumes using integration, it is important to consider both the axis of revolution and the specific form of the functions describing the boundaries. In general, the simpler integral should be chosen. For example, when considering the area under the graph e^(-x) and x in [1,2] being revolved around the x-axis, the disk method is the natural choice, while the shell method would be better for revolving around the y-axis. This is because in certain situations, one method may be easier to use than the other.
dnt
238
No specific question but what is the best way to determine which method is the best for solving for volumes (using integration) of shapes as they revolve around axis/lines. disk method? washer method? shell method? other?
what exactly do you look for that may hint towards one method over the other?
n/a
It depends on what axis they're revolving.
Which is better depends not only about which axis they are revolving but also the specific form of the functions describing the boundaries. About the only thing one can say in general is to consider each and decide which gives the simplest integral.
well you only have two axis, right? if its x which is best? if its y which is best?
to do volume with calculus: whether you chop the object up into thin disks or thin shells depends highly on the shape of the object. eg: consider the area under the graph e^(-x) and x in [1,2], if vol. is formed by revolving this area about x axis, then disk method is the natural choice, whereas if revolved about y axis, then shell method would be better.
why? what made you pick one over the other? what specifics do you look for that would cause you to lean towards one method over the other?
Because one of the methods is easier than the other. In certain situations, the shell method is easier to do than the disk method.
And we all know mathematicians are lazy. ;)
Think about it this way: if you were to find the area of a cone (y = x) that revolved around the x-axis, you'ld use the disk method. Not saying that you can't use the shell method, but its just easier to use disk.
Related to Determining best method for volumes?
1. What is the purpose of determining the best method for volumes?
The purpose of determining the best method for volumes is to find the most accurate and efficient way to measure the volume of a given object or substance. This is important in many scientific fields, such as chemistry, physics, and engineering, as it allows for precise calculations and reliable data.
2. What factors should be considered when determining the best method for volumes?
There are several factors that should be considered when determining the best method for volumes, including the shape and size of the object or substance, the precision and accuracy required, the availability of equipment and resources, and the potential for error or variability in measurements.
3. How do scientists determine the most accurate method for measuring volumes?
Scientists determine the most accurate method for measuring volumes by conducting experiments and comparing the results of different methods. They may also use mathematical models and statistical analysis to determine the level of precision and reliability of each method.
4. What are some common methods for measuring volumes in scientific experiments?
Some common methods for measuring volumes in scientific experiments include using graduated cylinders, burettes, pipettes, and volumetric flasks. These tools allow for precise measurements of liquid volumes, while solid volumes may be measured using displacement methods or geometric formulas.
5. Are there any potential sources of error when determining the best method for volumes?
Yes, there are several potential sources of error when determining the best method for volumes. These may include human error in measurements, variations in equipment or instruments, and inconsistencies in the properties of the object or substance being measured. It is important for scientists to carefully consider and account for these sources of error in their experiments.
