Determining components of 4-velocity
  • Thread starter Ned Stark
  • Tags
    Components
In summary, the 4-velocity of a particle following the spacetime trajectory x(τ) is u(τ) = (A, B, -ωCsinτ, ωCcosτ), and A must equal sqrt[1 + B^2 + (ωC)^2] in order for u^2 to equal -c^2.
Ned Stark
A particle of mass m follows the spacetime trajectory x(τ) = (Aτ, Bτ , C cosτω, C sinτω ).
What is the 4-velocity u(τ)? Why must A =sqrt[1+B^2+(ωC)^2]
u(τ)=dx(τ)/dτ , u^2 = -c^2
so I took the derivative of each comp of x with respect to tau and got:
u(τ)=(A, B , -ωCsinτω, ωCcosτω)
and 4-velocities always square to -c^2
so -A^2 +B^2 +(ωC)^2 = -c^2, which gives A =sqrt[c^2+B^2+(ωC)^2]
Why is my answer wrong?
Your answer is incorrect because you have squared the components of the 4-velocity. The 4-velocity is a vector, so it should not be squared. The correct answer is u(τ) = (A, B, -ωCsinτ, ωCcosτ). This satisfies the condition u^2 = -c^2, as required.
As for why A =sqrt[1+B^2+(ωC)^2], this is because the magnitude of the 4-velocity is always equal to c, the speed of light. So, we have:
u^2 = -c^2
(A^2 - B^2 - (ωC)^2) = -c^2
A^2 - B^2 - (ωC)^2 + c^2 = 0
Using the Pythagorean theorem, we can rewrite this as:
(A^2 + B^2 + (ωC)^2) = c^2
And since the magnitude of the 4-velocity is always equal to c, we have:
A^2 + B^2 + (ωC)^2 = c^2
Which leads to:
A = sqrt[1 + B^2 + (ωC)^2]
This is why A must equal sqrt[1 + B^2 + (ωC)^2] in order for the 4-velocity to satisfy the condition u^2 = -c^2.
Related to Determining components of 4-velocity
1. What is the 4-velocity and why is it important in determining components?
The 4-velocity is a vector that describes the speed and direction of an object in a four-dimensional space-time. It is important in determining components because it allows us to analyze the motion of an object in a relativistic framework.
2. How do you calculate the components of 4-velocity?
The components of 4-velocity can be calculated using the equation u^μ = dx^μ/dτ, where u^μ is the 4-velocity vector, dx^μ is the change in position in the four dimensions, and dτ is the proper time.
3. What are the units of 4-velocity?
The units of 4-velocity depend on the units of space and time being used. In the SI system, the units are meters per second (m/s).
4. How does 4-velocity differ from regular velocity?
4-velocity takes into account the effects of relativity, such as time dilation and length contraction, whereas regular velocity only considers the speed and direction of an object in three-dimensional space.
5. What applications is 4-velocity used for?
4-velocity is used in various applications, including special relativity, general relativity, and particle physics. It is also used in the study of black holes, cosmology, and high-energy physics experiments.
22K
