Determining Current and Voltage Drop in RLC Circuit
In summary: However, in this particular case, I can grant you a limited exception. The complete solution can be found on this website:In summary, the current in the circuit is .113 A and the voltage drop across each component of the circuit is 21.88-166.89° V.
theunbeatable
A circuit contains a 100Ω resistor, a .0500H inductor, a .400μF capacitor, and a source of time-varying emf connected in series. The time-varying emf is 50.0 V at a frequency of 2000 Hz.
a) Determine the current in the circuit.
b) Determine the voltage drop across each component of the circuit.
I = V / Z
Z = sqrt (R2+ (XL - XC)2)
XL = ωL
XC = 1 / (ωC)
ω = 2∏f
Vemf = VR + VC + VL (Kirchoff's Loop Rule)
V = IX, IR
Using the above equations, I got XL to be 628.3 and XC to be 198. I got Z to be 441, and solved for I: I = 50/441 → .113 A to get the current. The issue is, when I get the voltage drops across the components, they don't add up to 50 V. For the inductor alone, I got V = IXL, which ended up being 71 V. I'm not sure where I'm going wrong with this problem.
What do you get if you add the components? Did you consider the phase shift between the currents and voltages?
I got around 105 V when I add the components. As for the phase shift, I guess I didn't, but I'm not entirely sure what you mean by that.
When the capacitor has its maximal voltage, the current is zero, and the resistor has no voltage drop. When the resistor has its maximal voltage, the current is maximal, and the capacitor has no voltage drop.
And similar for the coil.
For every moment in time, the voltages have to add up to the source voltage. The maximal (or RMS) voltages of the individual components do not have to do that.
Ohh okay I get it. They all reach maximal points at different times, so I'm calculating each component's maximal voltage drop? Still, it wouldn't make sense for the inductor to have a maximal voltage that goes over 50 Volts.
Oh, that can make sense. You have a resonant circuit.
XL = 628.32 ohm
XC = 198.94 ohm
Z = R + jXC - jXL
= 100 + j628.32 - j198.94
= 440.87 < 76.89° (phase angle)
current in the circuit,
I = V/Z = 0.11 < -76.89°A
VR = I x R = (0.11 < -76.89°) x (100 < 0°) = 11<-76.89°V
VL = I x jXL = (0.11 < -76.89°) x (628.32 < 90°) = 69.12<13.11°V
VC = I x (-jXC) = (0.11 < -76.89°) x (198.94 < -90°) = 21.88<-166.89°V
how to calculate total voltage?
V = VR + VL + VC
= (11<-76.89°) + (69.12<13.11°) + (21.88<-166.89°)
= 48.50 < 2.05° v
Likes DaveE
XL = 628.32 ohm
XC = 198.94 ohm
Z = R + jXC - jXL
V = VR + VL + VC
= 48.50 < 2.05° v
Hello @miazahara .
:welcome:
The thread you are responding to is more than 9 years old.
Generally, when replying to threads, posting complete solutions is not allowed.
Likes berkeman
Related to Determining Current and Voltage Drop in RLC Circuit
What is an RLC circuit?
An RLC circuit is a type of electrical circuit that contains a resistor (R), an inductor (L), and a capacitor (C). These components are connected in series or parallel and can be used to analyze the behavior of AC circuits.
What is current in an RLC circuit?
Current is the flow of electric charge through a circuit. In an RLC circuit, current is determined by the voltage applied and the resistance, inductance, and capacitance of the circuit. It can be calculated using Ohm's Law (I = V/R) or by using Kirchhoff's Laws.
How do you calculate voltage drop in an RLC circuit?
Voltage drop is the decrease in voltage across a component in a circuit. In an RLC circuit, voltage drop can be calculated by using the formula V = IZ, where V is voltage, I is current, and Z is the impedance of the circuit. Impedance takes into account both resistance and reactance (the opposition to current flow caused by inductors and capacitors).
What is resonance in an RLC circuit?
Resonance in an RLC circuit occurs when the reactance of the inductor and capacitor cancel each other out, resulting in maximum current flow and minimum impedance. This is the point where the circuit is most efficient and can be useful for applications such as tuning radio receivers.
How can I measure current and voltage in an RLC circuit?
To measure current, you can use an ammeter, which is connected in series with the circuit. To measure voltage, you can use a voltmeter, which is connected in parallel with the component you want to measure. It is important to use the correct range on the meters and to make sure they are connected correctly to get accurate readings.
