Determining degrees of freedom
In summary, the number of degrees of freedom for a diatomic gas molecule in an enclosure with constant interatomic distance is 3*2-1 = 5. The number of degrees of freedom for two particles constrained to move on a plane connected by a massless spring is 1*2-0=2.
sudipmaity
50
Find the number of degrees of freedom for:
1. A diatomic gas molecule in an enclosure with constant interatomic distance.
2. Two particles constrained to move on a plane connected by a massless spring.
Nn-k
Where n=no. of dimensions.
N=no.of particles.
k=no.of constraints
1.N=2, n=3, k=1
So DOF=3*2 -1 =5
2.The particles are free to move on a plane.So if x describes the posn. y and z should be fixed.
So here n=1, N=2, k=0 (spring is massless).
So DOF=1*2-0=2.
Am i right??
Nn-k
N=no.of particles.
k=no.of constraints
1.N=2, n=3, k=1
So DOF=3*2 -1 =5
Right.
The position on a plane is given by two coordinates. The plane is two-dimensional, n=2
ehild
Likes sudipmaity
Sorry. I guess it should be then DOF =4 for 2nd problem.
It is :)
Correct me if I am mistaken but should part 2 not also be 5 DOF?
The massless spring between two particles is the analogy that is used to describe a diatomic molecule.
We have 2 translational DOF, 2 rotational DOF and vibrational DOF.
You use the formula for number of degrees of freedom = Nn - k where N is the number of particles and n is the number of dimensions. A plane has two dimensions. There are two particles. There are no constraints.
On the plane, a two-atomic molecule has only one kind of rotation: with axis, perpendicular to the plane. It can not move out of the plane. And it has one kind of vibration.
It is a different thing that applying equipartition principle, the vibrational degrees of freedom count twice when calculating the average energy of the molecule, as vibrational energy is the sum of KE and elastic potential energy.
ehild
Related to Determining degrees of freedom
1. What does "degrees of freedom" mean in scientific research?
Degrees of freedom refer to the number of independent variables or parameters that can vary in a statistical model without affecting the number of observations or data points. It is a measure of the flexibility or variability in a system.
2. Why is it important to determine degrees of freedom?
Determining degrees of freedom is important in statistical analysis because it helps to determine the appropriate statistical tests to use and the accuracy of the results. It also allows researchers to assess the reliability and generalizability of their findings.
3. How do you calculate degrees of freedom?
The formula for calculating degrees of freedom varies depending on the statistical test being used. In general, degrees of freedom can be calculated by subtracting the number of constraints or restrictions in a system from the total number of variables or data points.
4. Can degrees of freedom be negative?
No, degrees of freedom cannot be negative as it represents the number of parameters that can vary freely in a system. If the calculated degrees of freedom is negative, it is likely that there is an error in the calculation or the model being used.
5. How does sample size affect degrees of freedom?
As the sample size increases, the degrees of freedom also increase. This is because with more data points, there is more variability and less constraint in the data, resulting in a higher number of degrees of freedom.
  • Mechanics
