Determining electric field using gauss's law--different distributions
Gauss's law can be applied effectively when there is symmetry in the charge distribution. The discussion highlights that distributions A and D lack the necessary symmetry for using Gauss's law, while B and C are more suitable. The key to applying Gauss's law is to choose a surface where the electric flux remains constant. Participants suggest that distribution A could be analyzed as a line of charge with an imaginary cylinder, but the asymmetry complicates its application. Overall, understanding the symmetry of charge distributions is crucial for determining the electric field using Gauss's law.
Helenah
We are supposed to determine which (if any) of the distributions will need to/could use Gauss's law to determine the electric field
flux = Q/electric constant = EA
These are the 4 distributions shown, and I have to determine which two distributions (or none at all) can use Gauss's law to determine the electric field.
So electric flux = EA = Q/electric constant.
Since all of them have charges, I could do something like Q/(A*electric constant) to get the electric field—that's where I'm confused, because I think I could actually use Gauss's law on all four of them. The only other way I can think of is that Gauss's law is applied to surfaces so that probably excludes lines (A) and disks (D), which do not really have surface area.
Am I right in thinking so? Is there a better / correct way to get to the answer?
You perhaps need to think about how you would practically use Gauss's law to determine the electric field.
Hint: think about symmetry.
@PeroK
Hmm. Distribution A could potentially be viewed as line of charge + imaginary cylinder to get some electric field, but the charges aren't symmetric and hence will not be able to use gauss's law (?).
I'm not sure where else it's not symmetric though.
Helenah said:
@PeroK
The trick to use Gauss's law effectively is to have a surface across which the electric flux must be constant.
Your intuition is right that A and D are problematic and B and C are better. Can you explain more clearly how you do things in cases B and C?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
