Does a Particle Moving on a Curve Separate Under Gravity?
In summary: It doesn't, but forgive me but I do not understand at all what does that mean for my problem?Are you saying that you have learned about when the Lagrangian does not depend on one of the coordinates explicitly, but you have not seen the Beltrami identity?Yes, I think I understand what you are saying. In that case, the Lagrange equation for ##\lambda## would be$$\lambda = -mg+2bm(x\ddot x+\dot x^2)$$
Argelium
25
Consider a particle moving over the curve ##z=a-bx^2## under the force of gravity. If the particle starts from rest at point ##(0,0)## (I'm guessing it means point ##(0,a)##), tell if the particle ever separates from the curve; if yes, find the point at which it does.
$$\frak{L} = T-U$$
$$\frac{\partial\frak{L}}{\partial q_i}-\frac{d}{dt}\left(\frac{\partial\frak{L}}{\partial \dot q_i}\right)+\sum_{k=1}^n \lambda_k\frac{\partial f_k}{\partial q_i} = 0$$
Well, clearly it's a problem suited for Lagrangian mechanics. We have the coordinates to be ##x, z## and the Lagrangian to be
$$\frak{L} = \frac{m}{2}(\dot x^2+\dot z^2)-mgz$$
Then the Lagrange equations are:
$$m\ddot x+2b\lambda x=0$$
$$-mg-m\ddot z-\lambda = 0$$
Then applying the constraint we obtaint the equations:
$$mg+2bm(x\ddot x+\dot x^2) = \lambda$$[/B]
How do I proceed to obtain ##\lambda##? I'm seriously stuck on here, so I'd appreciate if you could tell whether I am on the right track or not, and if yes, how to proceed.
Thanks!
You also need to use the constraint equation, which is the EL equation for ##\lambda##.
Yea, I wasn’t very explicit on the original post. But the constraint equation is
$$f(x,z)=a-z-bx^2=0$$
Using that and plugging them on the EL equations (of the first kind) we arrive at the last two equations I typed
You have two different differential equations, both involving ##\lambda##. You would typically eliminate ##\lambda## from those and solve the differential equations. Then you can find ##\lambda## by inserting the solution into one of the equations.
However, I suggest that you replace one of your EL equations by a suitable constant of motion.
However nothing is a constant of motion in this problem, right?
Why would you think so?
If I recall,##\dot q_i## is a constant of motion if ##\frac{\partial L}{\partial q_i}=0## and that is not the case here.
This is only a sufficient condition for a constant of motion to exist, not a necessary one.
Hint: Does your Lagrangian depend explicitly on time?
More generally, both are manifestations of Noether's theorem.
Related to Does a Particle Moving on a Curve Separate Under Gravity?
What is the definition of "determining force of constraint"?
The determining force of constraint is the force that keeps an object or system in a specific position or state of motion. It can be either a physical force, such as tension in a string, or a mathematical force, such as a Lagrange multiplier.
How do you calculate the determining force of constraint?
The determining force of constraint can be calculated using equations of motion, such as Newton's laws or the principle of virtual work. It may also involve solving for unknown variables using constraints and Lagrange multipliers.
What are some real-world examples of determining force of constraint?
Some examples of determining force of constraint include the tension in a rope holding a hanging object in place, the force of gravity keeping a satellite in orbit, and the normal force preventing an object from falling through a surface.
What is the difference between a holonomic and non-holonomic constraint?
A holonomic constraint is one that can be expressed as an equation involving only the position coordinates of a system. In contrast, a non-holonomic constraint involves the velocity or acceleration of the system, making it more complex to incorporate into equations of motion.
Why is determining force of constraint important in physics and engineering?
Determining force of constraint is essential in analyzing and predicting the motion of objects and systems. It allows scientists and engineers to understand the forces at play and design structures and machines that can withstand and utilize these forces effectively.
