MHB Determining if a sequence is arithmetic
The sequence defined by An = 2 + 6n produces the first five terms: 2, 8, 14, 20, and 26. To determine if it is an arithmetic sequence, the difference between successive terms must be constant. The calculation shows that a(n+1) - a(n) equals 6, confirming that the difference is indeed constant. Therefore, the sequence is classified as an arithmetic sequence. The conclusion is that the sequence meets the criteria for being arithmetic due to the consistent difference of 6.
fluffertoes
Question:
Find the first 5 terms of this series and determine if it is an arithmetic sequence.
An= 2 + 6n
Help please!
Mathematics news on Phys.org
Re: Sequences and series help ASAP please!
fluffertoes said:
Question:
An= 2 + 6n
Help please!
If we have an AP, then we must have:
$$a_{n+1}-a_{n}=C$$ where C is some constant...is this what we have?
All the info i was given is what I put in the original question up there, yikes
We are given:
$$a_{n}=2+6n$$
Therefore:
$$a_{n+1}=2+6(n+1)$$
So, what is the difference:
$$a_{n+1}-a_{n}$$ ?
MarkFL said:
We are given:
$$a_{n}=2+6n$$
Therefore:
$$a_{n+1}-a_{n}$$ ?
1? I'm not sure
fluffertoes said:
1? I'm not sure
Let's work it out...
$$a_{n+1}-a_{n}=\left(2+6(n+1)\right)-\left(2+6n\right)=\left(2+6n+6)\right)-\left(2+6n\right)=(2+6n)+6-(2+6n)=6$$
This tells us that any two successive terms in the given sequence differ by 6, which is a constant, and therefore we do have an arithmetic sequence. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
