Determining if equation is linear in indicated dependent variable
In summary: Re: determining if equation is linear in indicated dependent variableIn summary, the conversation revolves around determining if an equation is linear in an indicated dependent variable. The equation in question is (y-x)dx +4xy dy = 0, and there is confusion about the presence of dx and dy and how the equation was rewritten. It is clarified that integrals also contain a differential and that the equation cannot be rewritten in the given form. The conversation then shifts to another equation and the process of determining if it is linear in a given variable. Ultimately, the question of whether the given equation is linear in v or u is left unanswered.
find_the_fun
148
I was stuck on a question and went back to look at an example but couldn't understand the example. It has \(\displaystyle (y-x)dx +4xy dy = 0\) is linear in y because it can be written as \(\displaystyle 4xy'+y=x\)
First of all what are dx and dy doing in the equation? They look to be from the end of an integral. Second, how did the equatin get rewritten like that?
Did you intend the original expression to instead be the equation:
\(\displaystyle 4x\,dy+(y-x)\,dx=0\) ?
This is in differential form. And yes, integrals also contain a differential (after the integrand usually), to denote with respect to what variable we are integrating.
No I didn't inted for the original expression to be that.
So the statement could be rewritten as \(\displaystyle \frac{d}{dx}(y-x)+\frac{d}{dy}4xy=0\) ?
We cannot take an expression and convert it into an equation.
I see what you mean now and yes you were right. Sorry about that. I thought your point was to move terms around and didn't look at the =0 at the end. I should have been more careful.
There is still a problem, since:
\(\displaystyle (y-x)\,dx +4xy\,dy=0\)
cannot be rewritten as:
or in standard linear form:
\(\displaystyle y'+\frac{1}{4x}y=\frac{1}{4}\)
However, the equation:
\(\displaystyle (y-x)\,dx+4x\,dy=0\)
can.
Unfortunately, the book contains a typo.
Ok well the original question I was working on is
Determine whether the given equation is linear in the indicated dependent variable by matching it with the first differential equation given in (7).
\(\displaystyle u dv+(v+uv-ue^u)du=0\) in v; in u​
I'm not sure if I'm doing this right. So \(\displaystyle u dv=0\) since u is treated like a constant. \(\displaystyle (v+uv-ue^u)du=v-ue^u-e^u\) since v is treated like a constant. Am I supposed to be looking at the dv and du to know which variable to differentiate with respect to? How does the "in v; in u" make a difference?
Okay, we are given the ODE:
\(\displaystyle u\,dv+(v+uv-ue^u)\,du=0\)
Without knowing the form given in (7), we may still assert:
If it is linear in $v$, then we will be able to rewrite the ODE in the form:
\(\displaystyle \frac{dv}{du}+f(u)v=g(u)\)
and if it is linear in $u$, then we will be able to rewrite the ODE in the form:
\(\displaystyle \frac{du}{dv}+f(v)u=g(v)\)
This is not apparent to me. This is the first time I've seen an equation with du or dv just floating around.
As an example consider the equation:
\(\displaystyle y=x^2\)
Differentiating with respect to $x$, we may write the ODE:
\(\displaystyle \frac{dy}{dx}=2x\)
In differential form, this ODE is:
\(\displaystyle dy=2x\,dx\)
FAQ: Determining if equation is linear in indicated dependent variable
What is a linear equation?
A linear equation is an algebraic equation that represents a line on a graph. It contains only variables that are raised to the first power and constants.
How can I determine if an equation is linear?
To determine if an equation is linear, you can check if it follows the form y = mx + b, where m is the slope and b is the y-intercept. If an equation does not follow this form, it is not linear.
What is the dependent variable in a linear equation?
The dependent variable in a linear equation is the variable that is being solved for or depends on the independent variable. It is typically represented by the y-axis on a graph.
Can an equation be linear in more than one variable?
Yes, an equation can be linear in more than one variable. This means that there are multiple variables that are raised to the first power and constants in the equation.
How do I graph a linear equation?
To graph a linear equation, you can plot the y-intercept (b) on the y-axis and use the slope (m) to find additional points on the line. Then, connect the points with a straight line to create the graph.
