Determining if the sequence convergers or diverges(IV)
  • MHB
  • Thread starter shamieh
  • Tags
    Sequence
In summary: So as n gets bigger and bigger, the square root gets smaller and smaller and eventually becomes 0.In summary, the sequence converges to 1/2.
shamieh
539
Determining if the sequence converges or diverges, if it converges find the limit
\(\displaystyle \sqrt{n^2 + n} - n\)
Wouldn't this just diverge if n--> infinity ?
I'm not sure what to do here? I can;t use lopitals...Also how would this converge to 1/2 is this a telescoping series?
No, $\displaystyle \begin{align*} \infty - \infty \end{align*}$ is an indeterminate form.
You would need to try to rationalise the numerator...
$\displaystyle \begin{align*} \sqrt{n^2 + n} - n &= \frac{\left( \sqrt{n^2 + n} - n \right) \left( \sqrt{n^2 + n} + n \right) }{\sqrt{n^2 + n} + n} \\ &= \frac{n^2 + n - n^2}{\sqrt{n^2 + n} + n} \\ &= \frac{n}{\sqrt{n^2 + n} + n} \\ &= \frac{n}{\sqrt{n^2 \left( 1 + \frac{1}{n} \right) } + n } \\ &= \frac{n}{n\sqrt{1 + \frac{1}{n}} + n} \\ &= \frac{1}{\sqrt{1 + \frac{1}{n}} + 1} \\ &\to \frac{1}{\sqrt{1 + 0} + 1} \textrm{ as } n \to \infty \\ &= \frac{1}{2} \end{align*}$
So the sequence converges to 1/2.
Also this is not a series, so again, don't try to see if this non-existent series is telescopic...
Hey thank you so much, but on the 5th step I think I'm confused. Where did the n^2 go? did you pull it out infront of the square root because it is a constant multiplier and if so if you pulled it out n/n^2 would be 1/n not 1/1 right?? Then you would take lim as n -> infty and get 0?
Surely you can see that $\displaystyle \begin{align*} \sqrt{n^2} = n \end{align*}$ (if n is nonnegative as it is since we are making it go to infinity)...
Oh I see.
FAQ: Determining if the sequence convergers or diverges(IV)
How do you determine if a sequence converges or diverges?
The first step is to take the limit of the sequence as the number of terms approaches infinity. If the limit exists and is a finite number, then the sequence converges. If the limit does not exist or is infinite, then the sequence diverges.
What is the definition of convergence for a sequence?
A sequence converges if its terms get closer and closer to a single fixed value as the number of terms increases. In other words, the limit of the sequence exists and is a finite number.
How do you find the limit of a sequence?
You can use various methods to find the limit of a sequence, such as direct evaluation, algebraic manipulation, or using known limit theorems. It is important to also check for any patterns or common differences in the terms of the sequence.
What does it mean if a sequence diverges?
If a sequence diverges, it means that its terms do not approach a single fixed value as the number of terms increases. This could be due to the terms getting larger and larger or oscillating between different values.
Can a sequence both converge and diverge?
No, a sequence can only either converge or diverge. It cannot do both. If the limit of a sequence exists and is a finite number, then it converges. If the limit does not exist or is infinite, then it diverges.
