Determining maximum coefficients of friction
In summary, the problem involves a block of weight 20 N on an inclined plane with an angle of 37°, and a coefficient of kinetic friction (μk) of 0.125. Using the given equations and solving for different cases, it is found that the weight components are 12 N and 16 N, and the acceleration is 6 m/s2 assuming no friction and 5 m/s2 assuming μk = 0.125. To make the block slide down at constant velocity, μk = 0.75 is needed, and the coefficient of static friction (μs) must be greater than 0.75 to prevent sliding. These values do
sleepcity
A block of weight 20 N (m = 2 kg) sits on an plane inclined at 37°. g = 10 m/s2 (for simplicity).
a) Calculate the value of the weight components.
b) Calculate the acceleration assuming no friction.
c) Calculate the acceleration assuming μk = 0.125.
d) What value of μk is needed to make the block slide down at constant velocity?
e) How great must μs be to prevent sliding?
f) In what way to the answers to d) and e) depend on the block's mass?
Taking the incline as the x-axis,
Fwx = Fwsinθ
Fwy = Fwcosθ
∑Fx: Fwsin37° - FF = max
∑Fy: Fwcos37° + FN = may
tan θ = tan 37° = 0.75
a) [/B]Fwx = 20sin37° = 12 N
Fwy = 20cos37° = 16 N = FN
b) ∑Fx: 20sin37° = 2a, ∴ a = 6 m/s2
c) ∑Fx: 20sin37° - FF = 2a,
12 - ((μk)(FN)) = 2a
12 - ((0.125)(15.97) = 2a
12 - 2 = 2a
a = 10/2 = 5 m/s2
d) Constant velocity implies a = 0.
∑Fx: Fwsin37° - FF= 0, ∴FF= 12 N -- The force of friction balances the component of gravity pulling the box down the incline.
If FF = 12 N, μk = FF/FN = 12/16 = 0.75
e) I know that the coefficient of kinetic friction (μk) is usually lower than the coefficient of static friction (μs). If I were told what force was required to disrupt equilibrium (no motion), μs would be given by (Force required/FN). Without knowing this force I'm not sure how to proceed next.
f) My suspicion is that these values do not depend on mass at all, since acceleration is zero in each of the cases described in d) and e) (constant velocity and no motion until the friction force resisting motion is overcome.
Any and all help is greatly appreciated.
Hello sleepy, and welcome to PF :)
In the e) case, you can consider a minute little force to start it sliding.
I don't agree with your force required/FN: there always is the 12 N from gravity that has to be compensated by friction.
For the answer, let the magnitude of this little force go to 0.
For f: you could repeat the calculations for a 4 kg block, but I think you already have seen that all forces that appear are proportional to m, so this m cancels
Related to Determining maximum coefficients of friction
1. What is the coefficient of friction?
The coefficient of friction is a dimensionless number that represents the amount of resistance between two surfaces in contact. It is a measure of how difficult it is to slide one surface over another.
2. How is the coefficient of friction determined?
The coefficient of friction can be determined experimentally by measuring the force required to move one surface over another, and then dividing that force by the weight of the object. It can also be calculated using mathematical models and equations based on the properties of the surfaces in contact.
3. What is the maximum coefficient of friction?
The maximum coefficient of friction is the highest possible value that can be achieved between two surfaces. It is dependent on the properties of the surfaces, such as their roughness, material composition, and lubrication.
4. How do you calculate the maximum coefficient of friction?
To calculate the maximum coefficient of friction, you need to know the properties of the surfaces in contact, such as their roughness and material composition. You can then use mathematical models and equations, such as Coulomb's law, to determine the maximum coefficient of friction.
5. Why is it important to determine the maximum coefficient of friction?
Determining the maximum coefficient of friction is important in many practical applications, such as designing machinery and structures, selecting materials for different surfaces, and predicting the behavior of objects in motion. It can help ensure safety, efficiency, and durability in various industries and everyday life.
16K
