Determining molecular formula of a hydrate? (HELP)
In summary, the molar ratio of MgSO4 to H2O is 1:5.25, suggesting a molecular formula of Mg4SO16*21H2O. However, due to the potential for varying levels of crystalline water and measurement inaccuracies, a more accurate formula may be Mg4SO16*5H2O.
camoflauge
MgSO4*xH20
mass of hydrated comlex (g) - 6.32
mass of anhydrous complex (g) - 3.54
mass of water (g) - 2.78
MolarMass MgSO4 = 120.38g/mol
MolarMass H2O = 18.02g/mol
Based on those results, determine the molecular formula of the hydrate.
n=m/M
nMgSO4 = 3.54/120.38 ---> 0.0294068782189733
nH2O = 2.78/18.02 ----> 0.1542730299667037
then to find the multiplier I must divide by the lowest mol;
0.0294068782189733/0.0294068782189733 = 1
0.1542730299667037/0.0294068782189733 = 5.246154617907276 / 5.25
therefore, for every MgSO4, there is 5.25H2O
Molecular formula: Mg4SO16*21H2O (since our teacher asks for integers only)
is this correct, or is it incorrect, help please!
The mole ratio you find between the anhydrous salt and the water is good, but maybe as for ratio of integers, you need larger numbers, so as to have a whole number for MgSO4 larger than 1. You will no longer have a "5" for the corresponding H2O part. Multiply, "0.25" by what to get a whole number? Then what do you do for the MgSO4 part?
I'm thinking more like,
5.25*4, H20, and 1*4, MgSO4.
Formula unit would be (MgSO4)4*21H2O
Note that hydrates often don't have nicely defined formulas and amount of crystalline water can depend on the humidity and the sample history (what was the temperature/humidity it was kept in lately). Often the composition is different on the surface and in the bulk. Add to that fact that measurements are always inaccurate, so you can't expect the ratio to be exactly an integer number.
I would go for 5H2O (rounding down) with a comment explaining why the result is what it is. Whether it will be accepted and praised depends on the teacher.
Related to Determining molecular formula of a hydrate? (HELP)
1. What is the purpose of determining the molecular formula of a hydrate?
Determining the molecular formula of a hydrate allows us to understand the chemical composition of a substance and how many water molecules are attached to each molecule of the compound. This information is useful for identifying the substance and predicting its properties.
2. How do you determine the molecular formula of a hydrate?
The molecular formula of a hydrate can be determined through an experiment called a gravimetric analysis. This involves heating a sample of the hydrate to remove the water molecules and then measuring the mass of the remaining compound. By comparing the mass of the compound to the mass of the water molecules, the ratio of the two can be determined, which gives the molecular formula.
3. What factors can affect the determination of the molecular formula of a hydrate?
Some factors that can affect the determination of the molecular formula of a hydrate include experimental errors, incomplete removal of water molecules, and impurities in the sample. It is important to carefully control these factors to obtain accurate results.
4. Can the molecular formula of a hydrate be determined without an experiment?
No, an experiment is necessary to determine the molecular formula of a hydrate. This is because the amount of water molecules attached to a compound can vary, and it is not possible to determine the exact ratio without performing an experiment.
5. What are some common examples of hydrates?
Common examples of hydrates include copper sulfate pentahydrate (CuSO4·5H2O), calcium chloride dihydrate (CaCl2·2H2O), and magnesium sulfate heptahydrate (MgSO4·7H2O). These compounds are often used in chemistry experiments and industrial processes.
11K
9K
