MHB Determining ratio of a 2 part mix
  • Thread starter Thread starter rustyskills
    Ratio
The discussion focuses on determining the percentage composition of a sand mix in a foundry, specifically the ratio of mechanically reconditioned sand to thermally reclaimed sand. Given the weights of each sand type and the overall mix, the equations M + T = 100 and 850M + 889T = 87800 are used to solve for the percentages. The solution reveals approximately 28.2% mechanical and 71.8% thermal sand in the mix. Participants express gratitude for the mathematical clarification, noting its practical application in the foundry setting. The conversation highlights the importance of accurate mix calculations for operational efficiency.
rustyskills
Mechanically reconditioned sand weighs 8.50#/gallon
Thermally reclaimed sand weighs 8.89#/gallon
A mix of these two kinds of sand weighs 8.78#/gallon
What is the % thermal and %mechanical in the mix?
I work in a foundry and we feed these two types of sand into a hopper that feeds a mixer. It's important to have a quick and reliable test that can be done on the shop floor that confirms that the mix is 60/40 or 70/30 etc.
I looked at a lot of calculators and examples online but didn't find any that fit the data I have collected. I sure would appreciate some help. Anyone want to set me straight on this? Thx
Mathematics news on Phys.org
Let's let $M$ be the percentage of mechanically reconditioned sand and $T$ be the percentage of thermally reconditioned sand.
So, we know that:
And we also know:
Solving this system, we find:
You could also state:
modern day (math) warrior, mean mean stride...
thank you. I can duplicate that but I don't fully understand it yet.
I get the 850M + 889T = 87800
can you show me a little more about how you got to the rest?
much appreciated.
Suppose we take the first equation:
and multiply it by $-850$, so that it becomes:
Now, recall we have:
Adding these two equation, we will eliminate $M$, to get:
which gives us:
And then taking the original first equation, and using this value for $T$, we have:
There it is! I guess this answers the age old question "Why do I have to learn this- I'll never use it." Math in the foundry... I thank you.
I still have some R&R concerns regarding sampling technique but we can easily test and measure that. The roadblock was the calculation of the mix and you have cleared that right up.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
