Determining the clamping force on a Tube
In summary, the conversation discusses the clamping force of a circular clamp with two screws securing it onto a hollow tube. The screws are torqued to 20 lb-in, and the question is asked about the amount of weight the clamp can support when attached to the tube 4" from the center. The clamping force is calculated using an online calculator, and the holding force is determined by multiplying it by the coefficient of static friction. A sketch of the arrangement is provided, and the relationship between the holding force and torque from the weight is explained. The conversation concludes with a reminder to test the setup slowly and use a generous safety factor on the clamping force.
mech3d
Given the following:
1. A hollow tube 0.875" O.D. with a 0.750" I.D.
2. A clam shell circular clamp 0.875" wide.
3. Two No. 8-32 screws securing the 2 halves of the clamp onto the tube.
4. Screws are torqued to 20 lb-in.
I am looking for how much weight that can be supported by the clamp (before twisting loose) when the weight is 4" from the center of the tube and connected perpendicular to the clamp. Assuming a rigid connection between the weight and the clamp.
Thanks for your help.
Mech3D
First compute the clamping force of the screws with this link:
http://www.engineersedge.com/calculators/torque_calc.htm
Then compute the holding force by multiplying by the coefficient of static friction (say 0.2 for a reasonable but safe number - but reaserch this for your actual materials)
It is as simple as that? According to the calculator the axial force is 609 lbs. Assuming 0.2 for the coefficient of friction we have:
609 lb X 0.2 = 121.8 lbs, therefore with 2 screws X 121.8 lbs = 243.6 lbs holding force.
So if I have 2.5 lbs of weight 4" from the center of the tube, then the induced torque is then 10 in-lbs from the center or from the outer surface of the tube 2.5 lbs X 3.563" = 8.9 in-lbs?
If this is correct, then what is the relationship between the holding force and the torque from the weight? How can I determine let's say the safety factor?
Thanks Again
Could you scan a sketch of your arrangement?
Here is a sketch of the question...
With this arrangement, you can see that the net moment must be zero to avoid slipping. Hence,
F_clamping X Radius_tube = F_applied X Larm
or,
F_applied = F_clamping X (Radius_tube / Larm)
Thus, the force you may apply at the end, F_applied, is less than the clamping force by the ratio:
Radius_tube / Larm = 0.4375 / 4 = 0.109
Test your setup slowly (add weight slowly) and use a generous safety factor (al least 3) on your clamping force you figured earlier.
Related to Determining the clamping force on a Tube
1. How is the clamping force on a tube determined?
The clamping force on a tube is determined by calculating the force required to hold the tube in place and prevent it from slipping or moving. This can be done by considering factors such as the weight of the tube, the material of the tube, and the angle of the clamping mechanism.
2. What is the equation for calculating clamping force on a tube?
The equation for calculating clamping force on a tube is: F = μN, where F is the clamping force, μ is the coefficient of friction, and N is the normal force exerted on the tube. This equation takes into account the material properties of the tube and the clamping mechanism.
3. How does the angle of the clamping mechanism affect the clamping force?
The angle of the clamping mechanism can greatly affect the clamping force on a tube. If the angle is too steep, the clamping force may not be enough to hold the tube in place. On the other hand, if the angle is too shallow, the clamping force may be excessive and could potentially damage the tube.
4. Can the clamping force on a tube be adjusted?
Yes, the clamping force on a tube can be adjusted by changing the parameters used in the calculation, such as the coefficient of friction or the normal force. Additionally, the angle of the clamping mechanism can also be adjusted to achieve the desired clamping force.
5. What are some common methods for measuring the clamping force on a tube?
Some common methods for measuring the clamping force on a tube include using a torque wrench, a force gauge, or strain gauges. These tools can provide accurate measurements of the force being exerted on the tube, and can help ensure that the clamping force is within the desired range.
  • General Engineering
10K
  • Mechanics
  • Mechanical Engineering
