Determining the dimension of a given PDE
In summary, determining the dimension of a given partial differential equation (PDE) involves analyzing the number of independent variables and the order of the derivatives present in the equation. The dimension can influence the methods used for solving the PDE and the nature of its solutions. Typically, the dimension corresponds to the physical or geometric context of the problem represented by the PDE, such as time and space variables in a physical system. Understanding the dimensionality is crucial for selecting appropriate numerical techniques and for interpreting the results meaningfully.
chwala
390
TL;DR Summary
Let me have the pde equation below as our point of reference;
##u_t+u_{xx} + u_{xxx} = 1##
Now in my understanding from text ...just to clarify with you guys; the pde is of dimension 2 as ##t## and ##x## are the indepedent variables or it may also be considered to be of dimension 1, that is if there is a clear distinction between time and space variables.
Your insight on this is appreciated.
Just to clarify, does ##uxxx## means ##ux^3## or ##u_{xxx}## ?
Dimension you mean is space-time, physical dimension L,T,M or number of variables ?
Amended. Dimension as it relates to pde's ...
chwala said:
TL;DR Summary: Let me have the two pde equations below as our point of reference;
##u_t+uu_{xx} + u{xxx} = 1## and ##u_t+u_{xx} + u{xxx} = 1##
Now in my understanding from text ...just to clarify with you guys; the first pde is of dimension 2 as there is no clear distinction between time and space variables whereas the second pde would be of dimension 1.
To answer @anuttarasammyak's question, I believe the third term in both equations is ##u_{xxx}##, but was missing the underscore following u. If we categorize these equations by their domains, since the independent variables are t and x, the domain is two-dimensional.
Likes chwala
Thanks, I got it. As for dimension, I would say all u, t and x are are dimensionless in the sense of physical dimension because 1 in RHS is dimensionless.
The definition may vary depending on the context...dimension may also be in reference to the spatial part of the pde...if there is a clear distinction between time and the space variables.
That doesn't make sense to me. The only independent variables are t and x. The function u evidently depends only on these two variables, so u(t, x) is a surface in three dimensions with a two-dimensional domain.
Here is the text page...
The page you uploaded reserves the term "dimension" solely for spacial variables, but not a temporal one. That seems a bit artificial to me, but whatever...
Likes chwala
From Wikipedia KdV equation:
Definition
The KdV equation is a nonlinear, dispersive partial differential equation for a function ##{\displaystyle \phi }## of two dimensionless real variables,
##{\displaystyle x} ## and ## {\displaystyle t} ## which are proportional to space and time respectively:[5]
It says "a function ##{\displaystyle \phi }## of two dimensionless real variables" .
I have not been falimiar with KdV equation form of RHS 1.
Likes chwala
