Determining the energy radiated by gravitational waves in a simple system
  • Thread starter rcatalang
  • Tags
    Gravitation
In summary, the study investigates the energy radiated by gravitational waves in a simplified system, focusing on the dynamics of binary systems and their inspiral phases. It derives formulas for estimating the energy loss due to gravitational radiation, employing general relativity principles. The findings emphasize the significance of mass, distance, and orbital characteristics on gravitational wave emissions, and provide insights into observational signatures for upcoming detection efforts.
rcatalang
We have two massive particles of mass ##m_1## and ##m_2## that approach each other from infinity up to a certain point, ##x_f##. One has to calculate the energy radiated through gravitational waves.
Equation of motion: ##\ddot{x}=\frac{-GM}{x^2}##.
Energy lost (disregarding constants): ##E\propto \int_{t=0}^{t_f} \frac{(\dot{x})^2}{x^4}##
I have tried simplifying the integral (turning into an integral in terms of position variables) using the equation of motion. It's easy to show:
$$\frac{1}{x^4}=\frac{(\ddot{x})^2}{(GM)^2} $$
And therefore one can write:
$$\frac{1}{(GM)^2}\int_{t=0}^{t_f} (\dot{x}\ddot{x})^2 dt = \frac{1}{(GM)^2}\int_{\infty}^{x_f} \dot{x}(\ddot{x})^2 dx $$
But I have no idea about how to continue further with this integral. Any ideas on how to solve this integral?
Let me show you how to work this out. For brevity I'll just assume both masses are equal, ##m_1 = m_2 = m##, but you can easily re-scale the following results for the case of non-equal masses.
The idea is to assume that, since we're in linearized theory, the dynamics given by the Newtonian equations of motion are roughly correct. So consider the two masses to be at ##\pm x(t)## (and starting at ##\pm x_0##, which we'll later take to be infinity). The separation at time ##t## is just ##2x(t)##, and applying Newton III for either particle gives:$$m\ddot{x} = - \frac{Gm^2}{(2x)^2}$$You can multiply through by ##\dot{x}## and integrate both sides, which gets you something similar to an energy equation:$$ \frac{1}{2} \frac{d}{dt} (\dot{x}^2) = \frac{d}{dt} \left( \frac{Gm}{4x} \right)$$Using the initial conditions gives you:$$\dot{x}^2 = \frac{Gm}{2} \left( \frac{1}{x} - \frac{1}{x_0} \right)$$Now we return to general relativity briefly. The GW power is proportional to ##\dddot{Q}_{ij} \dddot{Q}_{ij}##, where ##Q_{ij}## is the trace-free part of the quadrupole tensor ##I_{ij}##, defined by:$$I_{ij} = \int \rho(\mathbf{x}) x_i x_j$$where ##\rho(\mathbf{x}) = m\delta(x(t)) + m\delta(-x(t))## in this case. You can see that this only has one non-zero component, ##I_{xx}##,$$I_{xx} = 2mx(t)^2$$So we'll need to find an expression for ##\dddot{I}_{ij}##. Churning out all three derivatives gives you:$$\dddot{I}_{xx} = 12m \dot{x} \ddot{x} + 4m x \ \dddot{x}$$That may look slightly unwieldy, but we do actually have everything we need. Recall that ##\ddot{x} = -GM/(4x^2)##, which you can differentiate again to get ##\dddot{x}##. If you plug everything in, you get\begin{align*}
\dddot{I}_{xx} = - \frac{GM \dot{x}}{x^2} = -\frac{GM}{x^2} \sqrt{\frac{GM}{2}} \sqrt{\frac{1}{x} - \frac{1}{x_0}}
\end{align*}Since this is a homework problem, you have do some work as well. What is the trace free part ##\dddot{Q}_{ij} = \dddot{I}_{ij} - \frac{1}{3} \mathrm{Trace}(\dddot{I}) \delta_{ij}##? Note that ##\dddot{Q}_{ij}## also has ##yy## and ##zz## components. Therefore what is the gravitational power ##P(x)## as a function of ##x##?
Once you have the power ##P(x)##, you can easily integrate$$dE = P(x) dt = P(x) \frac{1}{\dot{x}} dx$$since we know ##\dot{x}## as a function of ##x##...
Likes PhDeezNutz
FAQ: Determining the energy radiated by gravitational waves in a simple system
What are gravitational waves?
Gravitational waves are ripples in spacetime caused by the acceleration of massive objects, such as merging black holes or neutron stars. They propagate at the speed of light and carry energy away from the system that generates them.
How is the energy radiated by gravitational waves calculated?
The energy radiated by gravitational waves can be calculated using the quadrupole formula, which relates the change in the quadrupole moment of a system to the energy emitted. For simple systems, such as binary systems, the energy can be computed by integrating the gravitational wave strain over time and considering the masses and distances involved.
What factors influence the amount of energy radiated in gravitational waves?
The amount of energy radiated in gravitational waves is influenced by several factors, including the masses of the objects involved, their separation distance, the speed at which they are moving, and the nature of their orbital motion (e.g., circular or elliptical). Higher mass and closer proximity generally result in greater energy emission.
Can gravitational waves be detected, and how does this relate to energy measurement?
Yes, gravitational waves can be detected using sensitive instruments like LIGO and Virgo. These detectors measure tiny changes in distance caused by passing gravitational waves. By analyzing the detected signals, scientists can infer the energy radiated by the source, as the amplitude of the waves is related to the energy released during the event.
What is the significance of understanding the energy radiated by gravitational waves?
Understanding the energy radiated by gravitational waves is crucial for astrophysics as it provides insights into the dynamics of extreme cosmic events, such as black hole mergers and neutron star collisions. It helps scientists test theories of gravity, understand the formation of these objects, and explore the fundamental nature of the universe.
