Determining the equation of the volume of a cylinder
In summary, the person is seeking help in determining the equation for the volume of a cylinder expressed in terms of just the radius, without using the height. However, it seems that the given information may be incomplete or incorrect, as the volume of a cylinder typically requires both the radius and height. More context and the exact wording of the question is needed to provide a complete answer.
bwell
Hi,
My knowledge is not too good and I'm trying to help my son find out how we would go about determining the equation of the volume of the cyclinder V(r), expressed in terms of r alone? We do not know how we would go about this without using l or h?
Any help would be really appreciative (Smile)
Mathematics news on Phys.org
bwell said:
Hi,
Since the volume of a cylinder depends both on the radius of the base and its height, either you have misunderstood what you are being asked to do, or have not posted the complete question.
Post the question exactly as worded and any other contextual material which sets up the background for the question.
CB
If the cylinder is of an equilateral one, then its diameter is equal to its height, i.e. D=h. But D=2r, so we have h=2r.
Then, the volume of the equilateral cylinder, V(r)=pi(r^2)h=pi(r^2)(2r)=2pir^3.
FAQ: Determining the equation of the volume of a cylinder
How do you calculate the volume of a cylinder?
The equation for calculating the volume of a cylinder is V = πr2h, where r is the radius of the base and h is the height of the cylinder.
Can you explain the variables in the volume equation for a cylinder?
The variable π represents the mathematical constant pi (approximately 3.14), r represents the radius of the cylinder's circular base, and h represents the height of the cylinder.
How do you determine the radius of a cylinder?
The radius of a cylinder can be determined by measuring the distance from the center of the circular base to the edge of the base. Alternatively, if the diameter of the base is known, the radius can be found by dividing the diameter by 2.
Is the volume of a cylinder affected by its orientation?
No, the volume of a cylinder remains the same regardless of its orientation. As long as the base and height measurements remain the same, the volume will not change.
What units should be used for the measurements in the volume equation?
The units used for the measurements in the volume equation should be consistent. For example, if the radius is measured in inches, the height should also be measured in inches. The resulting volume will then be in cubic inches.
