Determining the focal length of a gradient index lens
In summary, the focal length of the lens is the distance from the axis at which the ray's distance from the lens is the smallest.
marcnn
There are three subquestions in this question, all marked bold.
Let's consider a gradient index lens of thickness ##d##, whose refractive index changes with the distance from the axis with the following formula
$$ n(r) = n_1 + a r^2 $$.
Determine the lens's focal length ##f##. Consider only rays falling parallel to the axis, whose distance from it ##r_1## is small. Assume that ##\lvert \Delta r \rvert << d##, ##\lvert \Delta r \rvert << r_1##.
$$x(y) = d + \sqrt{R^2 - y^2} - R \approx d - \frac {y^2}{2R}$$
$$l(y) = x(y) \cdot n(y) + n_0\sqrt{[f + d - x(y)]^2 + y^2}$$
First of all, by the Fermat's principle we know that the light will travel with the path, for which the time or, equivalently ##\int_X^Y n dS## is minimal.
So I would say that the ray will approach the axis for ##a>0##. But in fact it is the opposite.
Why?
We can use the principle so as to calculate the focal length. The thickness of the lens depending on the distance from the axis is
Let the ray enter the lens at a distance ##y## from the axis at a point ##A##. Let it hit the lens's axis at point ##B##.
If ##f > 0##, then length of the ray's optical path between points ##A## and ##B## is
$$l(y) = x(y) \cdot n(y) + n_0\sqrt{[f + d - x(y)]^2 + y^2}$$ since ##\lvert \Delta r \rvert << r_1##.
But if ##f<0## then no ray hits the optical axis (only the rays' extensions). It is claimed that in this case
$$l(y) = x(y) \cdot n(y) - n_0\sqrt{[f + d - x(y)]^2 + y^2}$$
Why do we change the sign in this situation?
Later on it is claimed that ##f## is the focal length, then, ##l(y)## does not depend on ##y##. Why?
The statement of the problem does not mention a radius of curvature, so maybe it is intended to be a flat disk? The changing index will still cause it to act as a lens.
For a > 0, a flat disk would behave like a concave lens, since its thickness effectively increases with distance from the axis. If it also has curvature then whether it is efectively concave or convex will depend on the relationship between a and R.
Whooops! I forgot to mention it. The lens is planoconvex of radius ##R##
I think I can explain the sign change.
The term is the distance the ray has to travel through the air to reach the point B. In the second case, B is in front of the lens, so it is actually a distance that the ray did not have to travel in coming from B. Hence its contribution to path length is negative.
Yes, the light didn't have to travel the distance, indeed. but why do we take it in account then instead of ignoring?
There may be a better way to explain it in physical terms, but here's one way.
We need to find path lengths to a point B on the axis. But the ray never hits the axis in this case. So instead we consider the path length to some point C 'after' intersecting the axis (thinking of the ray as having come through air from a point B on the axis in front of the lens) then subtract the extra distance it has putatively traveled in air from B to C. The point C we choose is just after exit from the lens, but it could have been anywhere later to get the same result.
Related to Determining the focal length of a gradient index lens
What is a gradient index lens?
A gradient index lens is a type of lens that has a varying refractive index throughout its structure. This means that the lens is able to bend light at different angles depending on where the light enters the lens.
How is the focal length of a gradient index lens determined?
The focal length of a gradient index lens is determined by measuring the distance between the lens and the point where the light rays converge. This distance is known as the focal length.
What factors affect the focal length of a gradient index lens?
The refractive index profile, lens thickness, and curvature of a gradient index lens all contribute to its focal length. In general, a higher refractive index and thicker lens will result in a shorter focal length, while a flatter curvature will result in a longer focal length.
How accurate is the process of determining the focal length of a gradient index lens?
The accuracy of determining the focal length of a gradient index lens depends on the precision of the measurement tools and techniques used. With careful measurements and calculations, the accuracy can be within a few millimeters.
Can the focal length of a gradient index lens be changed?
Yes, the focal length of a gradient index lens can be changed by altering the refractive index profile, lens thickness, or curvature. This can be achieved through various manufacturing processes or by applying external forces to the lens.
