1729
- 25
A vertical cylinder contains 50.0 mg of hydrogen gas. A free to move piston with area 27.0 cm2 is pressing down on the gas. The gas's temperature is equal to 25.0 degrees Celsius.
A 30 degrees Celsius increase in temperature occurs and the piston is elevated by 2.00 cm.
The molar mass of hydrogen gas is 2.02 g/mol.
The mass of the piston is equal to:
(a) 1.2 kg
(b) 1.8 kg
(c) 3.6 kg (correct answer)
(d) 4.0 kg
(source: Vlaamse Fysica Olympiade 2015, 1st Round
https://gyazo.com/f7c960fbef62943fb0432bcffd2468b8)
pV=nRT (ideal gas law)
V=Ah (substitution)
p=F/A (substitution)
Notice that the piston is free to move (isobaric process). The pressure exerted on the piston by the gas will remain constant during the experiment.
Suppose hydrogen gas is an ideal gas. We will devise a system of equation using the ideal gas law by considering the two situations.
Situation 1: ##pV=nRT \Rightarrow Fh=\frac{mRT}{M}##
Situation 2: ##pV=nRT \Rightarrow F(h+0.0200 \mathrm{\ m})=\frac{mR(T+30\mathrm{\ K})}{M}##
(note: T=298K, not 25 deg C)
By regarding the two situations as a system of equations, we obtain the solutions:
$$F=308.54 \mathrm{\ N} \land h=0.20 \mathrm{\ m}$$ There are two major forces which cause the piston to be at rest in both situations: gravity and the pressure exerted on the piston. By Newton's second law, the sum of the two forces is equal to zero Newton.
$$m=\frac{308.54 \mathrm{\ N}}{9.81 \mathrm{\frac{m}{s^2}}}=31.45 \mathrm{\ kg}$$ However, this is not a possible answer. What's wrong?
