Determining the masses of 2 stars in a binary system.
In summary, the binary star has a period of 30 years, a distance of 10pc, and a combined mass of 90+11.25=128.25 solar masses.
knowlewj01
110
A binary star is resolved on the sky, the orbit is circular, it has a period of 30 years and the semi-minor and semi-major axes are observed to be 0.5 and 4 arcseconds respectively. If the distance to the system is 10pc, what are the masses of the stars? give an answer in solar masses.
i guess this one has to be used:
M1+M2=[tex]\frac{4\pi^2a^3}{GP^2}[/tex]
also this one to eliminate one of the M's
M1r1=M2r2
got as far as drawing a diagram but I don't know what the semi major and minor axes correspond to, are they the radii of the circular orbits of the separate stars about the centre of mass? any help would be good. Cheers.
I don't know what they are playing at putting the minor axes in this questions...
Badly worded question, but I guess you should assume that the 2 stars are of similar mass and orbit in a circular fashion around a common center of mass. This means the stars share exactly the same orbit.
You are told that the maximum separation between the 2 stars is 4 arcseconds, from our point of veiw to the center of mass which which take as a point, this is 2 arcseconds either side of us for each star.
Given that the distance to the center of mass is 10pc, use simple trigonometry to find the distance from the center of mass to 1 of the stars - this distance will be shared by the other star.
2M = [tex]
[/tex]
Since you would have to change into units of AU and years, you can forget the constant and go ahead with:
2M = [tex]
\frac{a^3}{P^2}
[/tex]
Total separation (which a is) between the stars is double of the orbital radii. Plug in and divide by 2, you should get nice values for the stars in solar masses.
Ok, thanks i'll give this a go and see what comes out of it. It just threw me off when it said the orbit was circular but still had semi major and semi minor axes. Think it means that the distance from the first and second star to the CM are 0.5" and 4". Thanks, ill see what happens.
M1R1=M2R2
R1 and R2 are 0.5" and 4" respectively, I worked these out to be 5AU and 40AU at a distance of 10pc by geometry.
using the definition of centre of mass at the beggining of this post i found M2 in terms of M1, R1 and R2, this was
[tex]\frac{5M1}{40}[/tex]
Sub this value for M2 into:
M1+M2=[tex]\frac{a^3}{P^2}[/tex]
M1 turns out to be 90 solar masses
M2 turns out as 11.25 solar masses
can anyone see any problems with this?
Thanks
Related to Determining the masses of 2 stars in a binary system.
1. How do you determine the masses of 2 stars in a binary system?
To determine the masses of 2 stars in a binary system, scientists use a method called the binary star system method. This involves observing the orbital motion of the stars and using Kepler's laws of motion to calculate the masses.
2. What is the binary star system method?
The binary star system method is a technique used by scientists to determine the masses of 2 stars in a binary system. It involves observing the orbital motion of the stars and using Kepler's laws of motion to calculate the masses.
3. How does Kepler's law of motion help in determining the masses of stars in a binary system?
Kepler's laws of motion state that the orbital period and distance of two objects in orbit are related to their masses. By observing the orbital period and distance of the stars in a binary system, scientists can use these laws to calculate their masses.
4. What are some challenges in determining the masses of stars in a binary system?
One challenge in determining the masses of stars in a binary system is the presence of other objects, such as planets or other stars, that may affect the orbital motion. Another challenge is the accuracy of the measurements, which can be affected by factors such as gravitational lensing or instrument errors.
5. Why is it important to determine the masses of stars in a binary system?
Determining the masses of stars in a binary system is important for understanding the overall structure and dynamics of the system. It can also provide insights into the formation and evolution of the stars. Additionally, this information can be used to study other phenomena such as gravitational waves and exoplanets.
  • Astronomy and Astrophysics
  • Other Physics Topics
