Determining the power of a rotating system
In summary, power is the rate of doing work. The power it took to go from 0 rad/sec to 1.57 rad/sec is irrelevant. The Attempt at a Solution
Pinon1977
126
Force of 200 foot pounds of torque is being exerted on a axle of a disc which is turning at 1.57 radians. The disk has a moment of inertia of 234 kg per meter squared and it's 1.5 inch diameter axle has a prony brake installed applying a load of 200 foot pounds of torque at the axle. How much work and power is being created by this situation[/B]
W=fd
Moi
Power = f x d /time
1.57 rad/sec x 234 kg /m2 = 367 Nm
How does the prony brake get accounted f[/B]
Power (in Watts) = torque (in Nm) angular velocity (rads per second)
200 foot pounds is 271 NM so the power going in is..
271 * 1.57 = 425W
If the brake is also applying a torque of 271Nm then the same power is being dissipated into the brake.
Energy can't be created only moved or converted. In this case 425W is moving from the motor or whatever is turning the flywheel through the flywheel and into the brake. From there it leaves in the form of heat.
Likes scottdave
One thing to note about your formula: the units/dimensions do not correspond, so that can tell you that something is wrong with your formula
Wrong dimensions. Moment of inertia is mass times square of distance, not divided by square of distance.
And anyway if it's going at a constant angular velocity the moment of inertia is irrelevant to the question of power flow.
Likes Nidum
Yes you are right. I typed in the wrong symbol. Thank you.
But you guys bring up a good point. The MOI x angular velocity = angular momentum, correct? Or in my case angular momentum = 367 Nm. What us thia number used to determine? How is it relevant to power or work?
So right now we know there is 425 watts being accomplished by the system. If i want to know total power of the system, what else should be added to the 425 watts? The power it took to go from 0 rad/sec to 1.57 rad/sec?
Angular momentum is only relevant when the angular velocity is changing. For example...
If you put in more energy than you take out the energy stored in the flywheel increases eg it goes faster.
If you take out more energy than you put in the energy stored in the flywheel reduces eg it goes slower.
There are several way to express this but the most common is probably...
Net torque = MOI * angular acceleration
Where net torque is the sum of all torques acting on the wheel taking into account the direction in which they act. Note that if the wheel is going at a constant angular velocity the acceleration is zero so the net torque is zero eg
Driving torque + brake torque + friction torque = zero
Power is the rate of doing work. It's not really meaningful to add rates like that.
You can calculate the energy/work that was added to the flywheel using
Energy = 0.5 * MOI * angular velocity^2
Think of this energy as like the energy stored in a battery. You can only get it back if you discharge the battery eg slow down the flywheel. How much power you can extract just depends on how fast you discharge the battery eg how fast you slow down the flywheel. There is no way to get more energy out than you put in.
Suppose a flywheel was spun up until it contained 100 joules of energy, then you could choose how much power to extract from it as follows...
0w by not slowing it down
1w by stopping it in 100 seconds
10w by stopping it in 10 seconds
100w by stopping it in 1 second
1000w by stopping it 0.1 seconds
So it's up to you how much power you extract and that determines how long the flywheel can deliver it. If you don't want the flywheel to slow down you have to apply energy at the same rate you extract it eg at the same power.
Related to Determining the power of a rotating system
1. What is the definition of power in a rotating system?
Power is the rate at which work is done or energy is transferred in a rotating system. It is measured in watts (W) or horsepower (hp) and is calculated by multiplying the torque (rotational force) applied to the system by the angular velocity (rotational speed) of the system.
2. How do you determine the power of a rotating system?
The power of a rotating system can be determined by measuring the torque applied to the system and the angular velocity of the system. The formula for power is P = Tω, where P is power, T is torque, and ω is angular velocity.
3. What factors affect the power of a rotating system?
The power of a rotating system is affected by the magnitude of the torque applied to the system and the speed at which the system rotates. Other factors that can affect power include the mass and shape of the rotating object, as well as any friction or resistance present in the system.
4. How does the power of a rotating system relate to its efficiency?
The power and efficiency of a rotating system are inversely related. This means that as the power of the system increases, its efficiency decreases. This is because as more power is required to rotate the system, more energy is wasted in the form of heat or friction. However, a well-designed rotating system can maximize both power and efficiency.
5. Can the power of a rotating system be changed?
Yes, the power of a rotating system can be changed by altering the torque applied to the system or by changing the speed at which the system rotates. This can be achieved by adjusting the size or shape of the rotating object, changing the force or direction of the applied torque, or using gears or other mechanisms to control the speed of rotation.
