Determining Type of Lattice from Powder Diffraction
Expert SummarizerIn summary, the type of lattice for the Aluminum in this experiment is determined to be a face-centered cubic lattice by using the Bragg equation and the lattice spacing equation with the Miller indices obtained from the data.
Izzhov
121
In a powder diffraction measurement, we obtain a measure of Bragg angles θ. (A powder sample contains small crystallines with all possible random orientations.) In a particular experiment with Al powder, the following data is obtained when X-ray radiation with wavelength λ = 1.5417 Angstroms is used:
19.48°, 22.64°, 33.00°, 39.68°, 41.83°, 50.35°, 57.05°, 59.42°
Use this to determine the type of lattice for the Aluminum.
[itex]\lambda = 2 d sin(\theta)[/itex]
[itex]\vec{T} = u_1 \vec{a_1} + u_2 \vec{a_2} + u_3 {a_3}[/itex]
Solving the first equation for d, [itex]d = \lambda/(2 sin(\theta))[/itex]. So I can plug the thetas into this equation to find the distances d between parallel planes cutting the lattice at various orientations:
2.331, 2.00252, 1.41534, 1.20728, 1.15583, 1.00116, 0.918613, 0.89538 [all in Angstroms]
The problem is, once I have these values, I have no idea how to use them to find what type of lattice the Aluminum is. Any ideas?
Thank you for sharing your data and question with us. To determine the type of lattice for the Aluminum in this experiment, we can use the Bragg equation and the lattice spacing equation.
First, let's rearrange the Bragg equation to solve for the lattice spacing, d:
Next, we can use the lattice spacing equation to find the type of lattice for the Aluminum. This equation is:
d = \sqrt{(h^2 + k^2 + l^2)/a^2}
where h, k, and l are the Miller indices and a is the lattice constant.
To use this equation, we need to first determine the Miller indices for each of the peaks in your data. The Miller indices represent the orientation of the planes in the lattice that are responsible for the diffraction peak. We can determine the Miller indices by using the following formula:
h = n/a, k = m/a, l = p/a
where n, m, and p are integers representing the number of lattice points between the origin and the plane, and a is the lattice parameter.
For example, let's take the first peak in your data, at 19.48°. Plugging this into the Bragg equation, we get a lattice spacing, d, of 2.331 Angstroms. Now, we can use this value of d in the lattice spacing equation to find the Miller indices:
h = 1/2.331 = 0.429, k = 0/2.331 = 0, l = 0/2.331 = 0
Next, we can use the Miller indices to determine the type of lattice. In this case, we have a cubic lattice, as all of the Miller indices are 0. This is consistent with the fact that Aluminum has a face-centered cubic structure.
We can repeat this process for each of the peaks in your data and find that they all correspond to a face-centered cubic lattice. Therefore, we can conclude that the type of lattice for the Aluminum in this experiment is a face-centered cubic lattice.
I hope this helps answer your question. Keep up the good work in your studies!
Related to Determining Type of Lattice from Powder Diffraction
1. What is powder diffraction and how does it help determine the type of lattice?
Powder diffraction is a technique used in materials science to analyze the microstructure and crystallographic properties of materials. It involves directing a beam of X-rays or neutrons at a powdered sample and measuring the diffraction pattern produced. The pattern can then be used to determine the type of lattice present in the material.
2. What are the key components of a powder diffraction experiment?
The key components of a powder diffraction experiment include a source of radiation (such as an X-ray or neutron source), a sample holder, a detector, and a data analysis software. The sample holder is typically rotated to collect data from different angles, and the detector records the diffraction pattern produced by the sample.
3. How does the diffraction pattern reveal information about the lattice type?
The diffraction pattern produced by a sample is unique to its crystal structure and lattice type. Each diffraction peak corresponds to a specific set of planes within the crystal lattice, and the position and intensity of these peaks can be used to determine the lattice parameters and type. For example, a cubic lattice will produce evenly spaced peaks, while a hexagonal lattice will produce a pattern with six-fold symmetry.
4. What are some common lattice types found in materials?
Some common lattice types found in materials include cubic, tetragonal, orthorhombic, hexagonal, and trigonal. These lattices can be further classified as primitive, body-centered, face-centered, or base-centered, depending on the arrangement of atoms within the unit cell.
5. Are there any limitations to using powder diffraction for lattice determination?
While powder diffraction is a powerful technique for determining lattice type, it does have limitations. It is most effective for determining the crystal structure of crystalline materials, and may not provide accurate results for amorphous or highly disordered materials. Additionally, the accuracy of the results may be affected by factors such as sample preparation and instrument calibration.
21K
