MHB Determining Value of a in Matrix A with $\lambda$ = 0
  • Thread starter Thread starter Yankel
    Matrix Value
Yankel
Hello all,
Given the following matrix,
\[A=\begin{pmatrix} 2 & 6\\ 1 & a \end{pmatrix}\]
and given that
\[\lambda =0\]
is an eigenvalue of A, I am trying to determine that value of a.
What I did, is to create the characteristic polynomial
\[(\lambda -2)*(\lambda -a)+6=0\]
and given
\[\lambda =0\]
I got that a is -3.
Somehow I am not sure. Is there a way of finding the second eigenvalue before calculating a ?
Thank you !
You could use that the determinant is the product of the eigenvalues.
(Also, the trace is the sum of the eigenvalues, but in this case you do not need that to determine $a$. You could use it to determine the second eigenvalue, though.)
Yankel said:
Hello all,
and given that
\[\lambda =0\]
and given
\[\lambda =0\]
I got that a is -3.
Thank you !
Check the signs in that calculation! I think that it should be $-6$ in the characteristic polynomial.
Opalg, you are correct, it is -6 and therefore a=3. Am I correct ?
As Krylov pointed out, the trace is the sum of the eigenvalues.
So if one eigenvalue is 0, then the other is $\operatorname{Tr}A=2+a$.
And yes, a=3 is the correct solution.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
