Determining vector angle: why do we need to add 180°
In summary: This is why you need to specify the angle convention every time, or use a diagram or other method to make the meaning clear.In summary, the conversation discusses the use of conventions and agreements when specifying angles in math and science. It is important to have a common understanding of these conventions in order to avoid ambiguity and ensure the correct answer is obtained. The magnitude of each force is shown, and the direction angle for R is calculated using the convention of measuring from the positive x-axis. The need to add 180 degrees to the angle is also explained. Finally, it is noted that the use of parentheses is important in mathematical expressions to avoid incorrect results.
Benjamin_harsh
211
why we need to add 180 to 56?
The magnitude of each force is shown below:
F1 = 10 N
F2 = 20 N
F3 = 40 N
243784
[tex]R = \sqrt {Rx^2 + Ry^2}[/tex]
[tex]R = \sqrt {-10^2 -15^2} = 18N[/tex]
[tex]θ = tan^{-1} \frac{Ry}{Rx}[/tex]
[tex]θ = tan^{-1} \frac{Ry}{Rx} = 56[/tex]
To express the direction of R, we need to calculate the direction angle (i.e. the counterclockwise angle that R makes with the positive x-axis), which in our case is 180° + θ, i.e. 236°.
why 236 but not 56? why we need to add 180 to 56?
By convention angles are measured counterclockwise from the positive x axis.
Why so?
Benjamin_harsh said:
Why so?
Why not? There has to be a common convention.
Why so?
So that you don't have specify the convention every time you want to specify an angle.
Why so?
If you just say "56 degrees", then people will assume that this is the angle measured from the postive x-axis, and that will give the wrong answer.
When you tell someone something, you both have to have an understanding and agreement of some basic "rules". You may not think of you two having an agreement on how to specify things, but you actually do. Here in math and science, this agreement or convention are codified and clarified so that there is no ambiguity on what means what.
In my class, my students have the freedom to either use the standard convention and signify the value of the angle from the +x-axis, or they can show on a sketch where this angle is and use the sketch itself to define the angle being measured. Otherwise, without such a sketch, a quoted angle will be assumed to be measured from the the +x-axis.
Of course, if this is an answer you have to enter into an online test or hw, it better be in the format or convention that it requires.
Zz.
Likes hutchphd and PeroK
Problem Statement: why we need to add 180 to 56?
Relevant Equations: why we need to add 180 to 56?
F1 = 10 N
F2 = 20 N
F3 = 40 N
Not that it matters much, but what is the meaning of F1, F2 and F3 and what it their relation to the diagram?
Also, this is incorrect
##R = \sqrt {-10^2 -15^2} = 18N##
You should put parentheses where they belong. It probably doesn't matter here, but it may matter later.
why 236 but not 56?
Further to the answers above, you may also be wondering why ##\tan^{-1}## did not give the right answer. It is because tan is opposite/adjacent, and in the coordinate system these are both signed quantities. In the third quadrant they are both negative and (-y)/(-x)=y/x, so the value of tan is the same at (x,y) and (-x,-y).
By convention, the function ##\tan^{-1}## is defined as taking the value between -π/2 and +π/2. In principle, you always then need to decide whether to add π.
It is just like taking square roots. The function √ is defined as returning a nonnegative value; you must then decide whether the positive or negative value is appropriate.
FAQ: Determining vector angle: why do we need to add 180°
1. Why do we need to add 180° when determining vector angle?
We need to add 180° in order to account for the direction of the vector. Vectors have both magnitude and direction, and adding 180° ensures that the direction of the vector is taken into account when calculating the angle.
2. Can't we just use the angle between the two vectors without adding 180°?
No, because the angle between two vectors does not take into account the direction of the vectors. Without adding 180°, we would not have a complete understanding of the angle between the vectors.
3. Is adding 180° necessary for all types of vectors?
Yes, adding 180° is necessary for all types of vectors because it is a fundamental principle of vector mathematics. It ensures that we have a complete understanding of the angle between vectors.
4. How do we know when to add 180° when determining vector angle?
We add 180° whenever we are calculating the angle between two vectors. It is a standard practice in vector mathematics and allows us to accurately represent the direction of the vector.
5. Can adding 180° affect the accuracy of our calculations?
No, adding 180° does not affect the accuracy of our calculations. It is a necessary step in determining the angle between vectors and ensures that we have a complete understanding of the direction of the vector.
