Determining wether consciousness is required in the double-slit experiment
In summary: Nope... Wavefunction is non local so it can pass thru the event horizon.For example imagine a Bell experiment with 2 electons, but 1 electorns is directed into a black hole...1The wavefunction would not be able to escape from the black hole, implying that there would be no interference pattern again.
entropy1
1,230
71
Considering the double-slit-experiment version whereby only one electron is fired at once, and a measuring device is placed by one of the slits, which can determine through which slit te electron travels.
My question would be: Which case is sufficient to qualify as an observation that will collapse the wavefunction of the observed electrons, thereby destroying the interference-pattern?
1) The presence of a measuring device that is switched on and measuring by one of the slits, or
2) The observation of the results of the measurement from this device by a human being,
3) Otherwise?
This experiment could be relatively easy to do. Just place a measuring device by one of the slits, turn it on, totally discard the measuring results, and watch the surface behind the slits for an interference pattern to emerge or not. In my opinion, it will reveal wether consciousness is required to make an observation in the QM sense.
As far as I can tell (at the risk of making some concrete assertion about the problem of measurement!) it would. But to be honest, I don't think consciousness causing collapse is really an idea anyone takes seriously any more. Most people are quite happy to write it off as an ugly sollipsism.
3) Otherwise?
Such experiments have already been done. 1) turns out to be the correct answer. There will be no interference pattern even if you do not look at the result of the measuring device on the slit. The mere presence of this device turns out to be sufficient.
Does anyone have reference(s) to research on this?
It is so trivial that it does not really need a reference.
No, if the device is isolated from the environment (which is really difficult to achieve, there decoherence leaks even thru the thermal radiation) and is dropped into a black hole then there is no path information
First, if the device is isolated from the environment, then it is not even justified to call it a "measurement device".
Second, if the device is in the black hole, than the hole through which the wave function should pass is also in the black hole, so the wave function will not be able to escape from the hole, implying that there will be no interference pattern again.
It can be an ordinary measurement device, just far enough so it can not interact - FOR SOME TIME. After it enters out lightcone we can get a result of a measurement.
I don't get a picture. Far enough from WHAT? Lightcone of WHAT?
Are you talking about experiments of the type of
http://xxx.lanl.gov/abs/quant-ph/9903047
where interference in encoded in the coincidences between two entangled particles? If you do please let me know, because this is something very different from which we were talking about so far.
My bad, it is just double slit experiment... You're right.
It is a pleasure to discuss with you because we arrive at a consensus very soon. :smile:
Related to Determining wether consciousness is required in the double-slit experiment
1. What is the double-slit experiment?
The double-slit experiment is a classic physics experiment that involves shooting particles, such as photons, through a barrier with two parallel slits. The resulting pattern on a screen behind the barrier shows an interference pattern, indicating that the particles behave like waves.
2. How is consciousness related to the double-slit experiment?
There is a belief that consciousness may play a role in the outcome of the double-slit experiment. Some suggest that the act of observation or measurement by a conscious observer can affect the behavior of the particles, causing them to behave like particles instead of waves.
3. What evidence supports the idea that consciousness affects the double-slit experiment?
There have been various studies and interpretations of the double-slit experiment that suggest consciousness may have an influence. For example, some experiments have shown that the presence of a conscious observer can change the interference pattern observed on the screen. However, these results are still debated and not universally accepted.
4. Can the double-slit experiment be explained without the need for consciousness?
There are various alternate explanations for the results of the double-slit experiment that do not involve consciousness. Some propose that the particles interact with their surroundings, causing the interference pattern, while others suggest that the particles themselves have wave-like properties that can explain the results.
5. How can scientists determine if consciousness is required in the double-slit experiment?
Currently, there is no definitive answer to this question. Some scientists argue that further research and experimentation is needed to fully understand the role of consciousness in the double-slit experiment. Others believe that the involvement of consciousness is a philosophical question that may never have a concrete scientific answer.
