Determining when a system of equations has no solution and infinite solutions
In summary, the system of equations has no solution if the following conditions are met: a = 2, b = 3, d = 6, and c is not equal to 2 or 6. There are no values of a,b,c,d for which the system has infinite solutions.
Ankit2
Find the surface in terms of a,b,c on which the following system of equations has no
solution
ax-2y+3z=5
-x+y-bz=-3
2x+cy-2z=d
Could there be any values of a,b,c,d for which the system has infinite solution? (Justify).
Hello and welcome to MHB! :D
I have retitled your thread so that it indicates the nature of the question being asked.
We ask that our users show their progress (work thus far or thoughts on how to begin) when posting questions. This way our helpers can see where you are stuck or may be going astray and will be able to post the best help possible without potentially making a suggestion which you have already tried, which would waste your time and that of the helper.
Can you post what you have done so far?
solution
ax-2y+3z=5
-x+y-bz=-3
2x+cy-2z=d
Have you tried to solve the system? The first thing I notice is that if you multiply the second equation by "a" and add that to the first equation, you eliminate "x": (ax- 2y+ 3z)+ (-ax+ ay- abz)= (2- a)y+ (3- ab)z= 5- 3a. And that if you multiply the second equation by "2" and add that to the third equation, you also eliminate x: (2x- cy- 2z)+ (-2x+ 2y- 2bz)= (2- c)y- (2+ 2b)z= d- 6. Can you solve those two equations for y and z? If not what would stop you?
FAQ: Determining when a system of equations has no solution and infinite solutions
How do you know when a system of equations has no solution?
When graphing the equations, if the lines do not intersect at any point, then the system has no solution. This means that there is no combination of values for the variables that can satisfy both equations simultaneously.
What does it mean when a system of equations has infinite solutions?
If the equations are graphed and the lines overlap, then the system has infinite solutions. This means that any value for the variables that satisfies one equation will also satisfy the other equation.
Can a system of equations have both no solution and infinite solutions?
No, a system of equations can only have either no solution or infinite solutions. It is not possible for it to have both at the same time.
How can you determine if a system of equations has no solution or infinite solutions algebraically?
If, when solving the system of equations algebraically, you end up with a statement that is always false, such as 0=3, then the system has no solution. If you end up with a statement that is always true, such as 0=0, then the system has infinite solutions.
What is the significance of determining when a system of equations has no solution or infinite solutions?
Knowing whether a system has no solution or infinite solutions can help in finding the best approach to solving the system. It can also provide important information about the relationship between the equations and the variables involved.
