Determining whether an integral converges based on comparison
In summary: We need to make this assertion $(x + x^2)^{\frac{1}{3}} \le x$ where $1 \le a \le x$. (What is $a$ here, by the way?).Since $x > 1$, we can do: $ \frac{(x + x^2)^{\frac{1}{3}}}{x} \le \frac{x}{x}$Or $ \frac{(x + x^2)^{\frac{1}{3}}}{x} \le 1$But how can we evaluate $\frac{(x + x^2)^{\frac{1}{3}}
tmt1
234
I have this integral
$$\int_{1}^{\infty} \frac{1}{(x + x^2)^\frac{1}{3}} \,dx$$
I think this is smaller than
$$\int_{1}^{\infty} \frac{1}{(x^2)^\frac{1}{3}} \,dx$$
The latter converges since $p = \frac{2}{3}$ which is greater than 1. Therefore, since the first integral is smaller than the second integral it must also converge. However, the answer is that it diverges. What is the error in my logic?
Well for starters, is it really true that \(\displaystyle \frac{2}{3}>1\)?
We know that:
\(\displaystyle \int_1^{\infty}\frac{1}{x}\,dx\) diverges. So, what we can do is try to show that:
\(\displaystyle \left(x+x^2\right)^{\frac{1}{3}}\le x\) where \(\displaystyle 1\le a\le x\)
We know that:
If I raise each side to the power of 3, I get:
$$x + x^2 \le x^3$$
Is that enough proof that \(\displaystyle \left(x+x^2\right)^{\frac{1}{3}}\le x\)?
$$x + x^2 \le x^3$$
Since $1<x$, we can divide through by $x$ and then arrange as follows:
\(\displaystyle x^2-x-1\ge0\)
Where is this true?
Where is this true?
So
\(\displaystyle x^2-x\ge 1\)
and
\(\displaystyle x(x - 1)\ge 1\)
so it looks like this is true whenever x is greater than 1.
What about \(\displaystyle x=\frac{3}{2}\)?
What are the roots of $x^2-x-1=0$?
Where is this true?
I'm having trouble reasoning about this.
But how can we evaluate $\frac{(x + x^2)^{\frac{1}{3}}}{x}$?
FAQ: Determining whether an integral converges based on comparison
1. How do you determine if an integral converges based on comparison?
To determine if an integral converges based on comparison, you need to compare it to a known convergent or divergent integral. This can be done by using the comparison test, limit comparison test, or integral comparison test.
2. What is the comparison test for determining the convergence of an integral?
The comparison test states that if the integral you want to determine the convergence of is always less than or equal to a known convergent integral, then it also converges. Similarly, if it is always greater than or equal to a known divergent integral, then it also diverges.
3. How do you use the limit comparison test to determine convergence of an integral?
The limit comparison test involves taking the limit of the ratio of the two integrals in question. If the limit is a finite number, then both integrals either converge or diverge. If the limit is 0 or infinity, then the integrals diverge or converge respectively.
4. Can the comparison test be used for improper integrals?
Yes, the comparison test can be used for improper integrals as well. In this case, you would compare the improper integral to a known convergent or divergent improper integral.
5. Are there any other methods for determining the convergence of an integral?
Yes, in addition to the comparison test, there is also the ratio test and the root test. These tests involve taking the limit of the ratio or root of the integrand and determining the convergence based on the resulting value.
