I Determining whether an object will topple or move without a Slope Test
  • I
  • Thread starter Thread starter ao01
    object
To determine whether an object will topple or move without a slope test, focus on the ratios of maximal lateral to normal force (static friction coefficient) and the distance between the center of mass and the base of support. The friction coefficient must be greater than or equal to the tangent of the slope angle, in this case, 15 degrees, which is approximately 0.268. Additionally, the object's base shape, center of mass position, and any external forces will significantly influence its stability. A specific equation can be formulated to calculate these factors, allowing for predictions without physical testing. Understanding these principles is essential for designing a device that can operate safely on inclined surfaces.
ao01
TL;DR Summary
I want to determine whether an object will topple or move without a Slope Test. Is there an equation for this? What should I pay attention to when calculating this?
So by what mechanism would this object topple then ?
Perhaps you can describe some scenario ?
There are two ratios involved:
- maximal lateral to normal force (static friction coefficient)
- lateral to normal distance between center of mass and the base of support boundary
I want a device to be able to be used on a 15-degree slope, and I want to be able to calculate this with a certain equation without testing.
What have you got to put in such an equation ?
The friction coefficient, u ≥ Tan( 15° ) = 0.268
But the shape of the base, the position of the CoM, and any forces applied to the resting device will change the game.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
