Determining which energy level transfers cause peaks in x-ray spectra
In summary, the conversation discusses the determination of energy level jumps in x-ray spectra using a crystal analyser and the calculation of the correct value of n in Bragg's Law to find the energy of the beam. However, the conversation appears to be mixing two different techniques, x-ray diffraction and x-ray photoemission spectroscopy, which have different purposes and do not use the same methods. It is important to clarify which technique is being referred to in order to properly answer the question.
lrcarr
Hi all,
I'm wondering how, for each peak in an x-ray spectra from a material (and using a crystal analyser), it is determined which energy level jump the peak corresponds to?
How would you figure out the correct value of n to substitute into Bragg's Law to find the energy of the beam?
Thank you!
Science news on Phys.org
lrcarr said:
Hi all,
Thank you!
Your post is very puzzling because it appears that you are mixing two different things into one.
Bragg's Law is the description that you get from x-ray diffraction (XRD) technique. It doesn't measure "energy level jump". Instead, it gives you information about the crystal structure of the material. The "n" in Bragg's Law is the diffraction order, not energy level quantum number.
x-ray photoemission spectroscopy (XPS) measures "energy level", or rather, core-level energy states. It is often used to identify the chemical composition of a material. One does not make use of the Bragg's law in XPS (at least, not usually).
So which one of these two that you want?
Zz.
Likes berkeman
Related to Determining which energy level transfers cause peaks in x-ray spectra
1. What is the process for determining which energy level transfers cause peaks in x-ray spectra?
The process for determining which energy level transfers cause peaks in x-ray spectra involves conducting experiments using a variety of materials and analyzing their corresponding x-ray spectra. The peaks in the spectra are then compared to known energy level transitions in order to identify the specific energy levels responsible for the peaks.
2. How do you differentiate between different energy level transfers in x-ray spectra?
Differentiating between different energy level transfers in x-ray spectra can be done by analyzing the intensity and position of the peaks in the spectra. Higher intensity peaks typically correspond to higher energy level transfers, while the position of the peak can indicate the specific energy level involved.
3. What factors can affect the peaks in x-ray spectra?
The peaks in x-ray spectra can be affected by a variety of factors, including the material being analyzed, the energy level transitions present in the material, and the measurement technique used. Other external factors such as temperature and pressure can also impact the peaks in the spectra.
4. How can determining energy level transfers in x-ray spectra help in understanding the properties of materials?
Determining energy level transfers in x-ray spectra can provide valuable information about the electronic structure and properties of materials. By analyzing the energy level transitions, scientists can gain insight into the composition, bonding, and other characteristics of the material.
5. Are there any limitations to using x-ray spectra to determine energy level transfers?
While x-ray spectra can provide valuable information about energy level transfers, there are some limitations to this technique. The resolution and sensitivity of the measurement equipment can affect the accuracy of the results, and certain materials may have overlapping peaks, making it difficult to differentiate between energy level transfers. Additionally, the composition and structure of the material can also impact the interpretation of the spectra.
  • Atomic and Condensed Matter
