Deviation from Curie-Weiss law in magnetic susceptibility
In summary, the speaker is experiencing difficulties interpreting the magnetic susceptibility of their heavy compound Ce2RhIn8 doped with Pd on the Rh site. The curves measured along the c-direction follow the Curie-Weiss law at high temperatures but deviate from it at lower temperatures. The speaker is unsure how to explain this behavior, but suggests it could be due to Kondo effect or CEF effects. They also mention that the reciprocal susceptibility along the a-direction follows the CW law to about 15 K. It is possible that the deviation from the Curie-Weiss law could be caused by a combination of factors such as Kondo effect, CEF, intermediate valence, nonlinear spin-orbit coupling effects, or multiple exchange
kratochvilova
Hi, I have some problems with interpretation of my dates of magnetic susceptibility measured on heavy compound Ce2RhIn8 doped by Pd on Rh site. The curves measured along c-direction follow the Curie-Weiss law only in the high temperature region (~200-300 K) and then deviate from it. The curves are strongly convex. I know that the opposite case, a concave curve, can be explained by intermediate valence, but I am not sure how to explain this behavior - by CEF, Kondo...? Just to be accurate, the reciprocal susceptibility along a-direction follows CW law to ~15 K.
It is difficult to say without more data, but it is possible that the deviation from the Curie-Weiss law at high temperature could be due to Kondo effect or CEF (crystal field) effects. The former occurs when a localized magnetic moment interacts with delocalized conduction electrons and results in an increase in the susceptibility. The latter occurs when the crystal environment of the ions causes the splitting of otherwise degenerate energy levels, leading to a decrease in the susceptibility. A concave curve generally indicates a presence of intermediate valence, where the electrons can occupy different energy levels due to hybridization with other orbitals. It can also be caused by nonlinear spin-orbit coupling effects or multiple exchange interactions. In any case, it is likely that the behavior of the reciprocal susceptibility along the c-direction could be explained by a combination of several effects, which could include Kondo effect, CEF, intermediate valence, and so on. It is worth taking a closer look at the available data to see if you can identify the underlying mechanisms at play.
Related to Deviation from Curie-Weiss law in magnetic susceptibility
1. What is the Curie-Weiss law?
The Curie-Weiss law is a mathematical relationship that describes the behavior of magnetic materials at high temperatures. It states that the magnetic susceptibility of a material is directly proportional to the inverse of the temperature.
2. How does the Curie-Weiss law relate to magnetism?
The Curie-Weiss law helps to explain the relationship between temperature and magnetism in materials. It shows that as temperature increases, the magnetic susceptibility decreases, meaning that the material becomes less magnetic.
3. What is deviation from Curie-Weiss law?
Deviation from Curie-Weiss law is when a material's magnetic susceptibility does not follow the expected behavior according to the Curie-Weiss law. This can happen due to various factors such as impurities, defects, and interactions between magnetic moments in the material.
4. What causes deviation from Curie-Weiss law?
There are several factors that can cause deviation from Curie-Weiss law, including the presence of impurities or defects in the material, interactions between magnetic moments, and the effects of external magnetic fields. These factors can disrupt the alignment of magnetic moments and result in a deviation from the expected behavior.
5. How is deviation from Curie-Weiss law measured?
Deviation from Curie-Weiss law can be measured by comparing the experimental magnetic susceptibility data with the theoretical values predicted by the Curie-Weiss law. If there is a significant difference between the two, then it is an indication of deviation from the law. Other techniques such as X-ray diffraction and magnetic resonance imaging can also be used to identify the factors causing deviation from Curie-Weiss law.
  • Atomic and Condensed Matter
  • Astronomy and Astrophysics
