- 2,532
- 10,145
Researchers from Berkeley and MIT have made a clever solar powered device that can extract water from low humidity desert air.
Good for arid places, like Dune!
And later marketed the "Aunt Varoo Weight Loss Program" on late night TV.Orodruin said:If we are anyway talking fictional planets I want to point out that Luke Skywalker spent his childhood as a moisture farmer on Tatooine.
The marketing spin annoys me here. They put the words "solar powered" on it as a way to solve the high energy use problem by pretending it doesn't exist and then use an extremely inefficient thermoelectric cooler as the condenser.BillTre said:Researchers from Berkeley and MIT have made a clever solar powered device that can extract water from low humidity desert air.
russ_watters said:The marketing spin annoys me here. They put the words "solar powered" on it as a way to solve the high energy use problem by pretending it doesn't exist and then use an extremely inefficient thermoelectric cooler as the condenser.
The principle of concentrating the moisture by absorbing it at night and releasing it during the day is sound, but any Boy Scout can do it with a tarp and a shovel. In both cases, it'll keep you alive in an emergency, but the lack of continuous output makes it infeasible for widescale use.
The device on Dune is designed to provide protection against the harsh environment and sandstorms on the planet. It can also assist with navigation and communication.
The device uses advanced technology to create a protective energy shield that can withstand the extreme conditions on Dune. It also has built-in sensors and communication systems to aid in navigation and communication.
Yes, the device is designed to be user-friendly and can be easily operated by anyone with basic training. It also has a simple interface and can be customized according to the user's needs.
While the device is primarily designed for survival on Dune, it can also be used for other purposes such as scientific research, exploration, and even defense against potential threats.
Yes, the device is made from high-quality materials and is designed to withstand the harsh conditions on Dune for a long period of time. It also has a self-sustaining power source, making it a reliable and long-lasting tool.
