Dexter's question at Yahoo Answers regarding related rates
In summary, we are given the variables of elevation, height of the elevator, and horizontal distance of the observer. Differentiating with respect to time, we find the rate of change of angle of elevation. By using Pythagoras, we can find the value of cosine squared of the angle, and thus the final equations for the rate of change of angle of elevation. Plugging in the given data, we can find the specific values for the rate of change at different heights.
MarkFL
MHB
13,288
Here is the question:
I have posted a link to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Dexter,
I would let $E$ be the elevation of the observer, $h$ be the height of the elevator above the ground, and $w$ be the horizontal distance of the observer from the elevator shaft.
From the diagram, we see we mat then state:
\(\displaystyle \tan(\theta)=\frac{h-E}{w}\)
Differentiating with respect to time $t$ (recognizing that $\theta$ and $h$ are the only variables that change with time), we find:
\(\displaystyle \sec^2(\theta)\frac{d\theta}{dt}=\frac{1}{w}\frac{dh}{dt}\)
Multiplying through by \(\displaystyle \cos^2(\theta)\), we get:
\(\displaystyle \frac{d\theta}{dt}=\frac{\cos^2(\theta)}{w}\frac{dh}{dt}\)
By Pythagoras, we know:
\(\displaystyle \cos^2(\theta)=\frac{w^2}{(h-E)^2+w^2}\)
and thus we may state:
\(\displaystyle \frac{d\theta}{dt}=\frac{w}{(h-E)^2+w^2}\frac{dh}{dt}\)
Plugging in the given data, we have (in radians per second):
\(\displaystyle \frac{d\theta}{dt}=\frac{54}{(h-21)^2+18^2}\)
And so to answer the questions, we find:
\(\displaystyle \left.\frac{d\theta}{dt} \right|_{h=15}=\frac{54}{(15-21)^2+18^2}=\frac{3}{20}\)
\(\displaystyle \left.\frac{d\theta}{dt} \right|_{h=39}=\frac{54}{(39-21)^2+18^2}=\frac{1}{12}\)
FAQ: Dexter's question at Yahoo Answers regarding related rates
What are related rates?
Related rates refer to the rate at which two quantities change in relation to each other. In other words, how the change in one variable affects the change in another variable.
How do you solve related rates problems?
To solve a related rates problem, you must identify the variables involved and their rates of change. Then, you can use the chain rule to find the derivative of the equation that relates the variables. Finally, plug in the given values and solve for the desired rate of change.
Can you provide an example of a related rates problem?
For example, if a ladder is sliding down a wall at a rate of 2 feet per second, and the base of the ladder is 6 feet from the wall, how fast is the top of the ladder moving down the wall when the base is 8 feet from the wall? This is a related rates problem because the rate at which the ladder is sliding down the wall is related to the distance between the base of the ladder and the wall.
What is the importance of understanding related rates in science?
Understanding related rates is important in science because it allows us to analyze and predict the behavior of systems that are constantly changing. This is particularly useful in fields such as physics, chemistry, and biology where rates of change are important in understanding natural processes.
Are there any common mistakes to avoid when solving related rates problems?
Some common mistakes to avoid when solving related rates problems include forgetting to take the derivative, mixing up the variables, and not labeling the rates correctly. It is also important to make sure the units are consistent throughout the problem and to carefully consider the given information before setting up the equation.
