Diagonalising a system of differential equations
In summary: One more thing. The eigenstructures are not just the way to compute the solution. Often they are the best way to understand and visualize what is going on.That makes sense. I'm curious, do you have any examples of situations where the eigenstructure is a better way to understand the problem than solving for the individual eigenvectors?That makes sense. I'm curious, do you have any examples of situations where the eigenstructure is a better way to understand the problem than solving for the individual eigenvectors?There are a few examples where the eigenstructure can be a better way to understand the problem. One is when the eigenvectors
Frank Castle
580
23
Given a system of linear differential equations $$x_{1}'=a_{11}x_{1}+a_{12}x_{2}+\cdots a_{1n}x_{n}\\ x_{2}'=a_{21}x_{1}+a_{22}x_{2}+\cdots a_{2n}x_{n}\\ \ldots\\ x_{n}'= a_{n1}x_{1}+a_{n2}x_{2}+\cdots a_{nn}x_{n}$$ this can be rewritten in the form of a matrix equation $$\mathbf{X}'=A\mathbf{X}$$ Assuming the matrix ##A## is diagonalisable, such that ##A=SDS^{-1}##, where ##S## is a (constant) matrix formed from the eigenvectors of ##A## and ##D## is a diagonal matrix whose diagonal elements are the eigenvalues of ##A##, we can recast the differential matrix equation as $$\mathbf{X}'=( SDS^{-1})\mathbf{X}$$ and defining ##\mathbf{Y}=S^{-1}\mathbf{X}##, then $$(S^{-1}\mathbf{X})=D(S^{-1}\mathbf{X})\Rightarrow\mathbf{Y}'=D\mathbf{Y}$$and so we have mapped the complicated system of differential equations into a set of (equivalent) diagonalised differential equations.
My question is, what is the motivation for doing this? Is it simply that in doing so we are able to solve for a much simpler system of differential equations (we reduce the system from one containing ##n\times n## parameters to one containing ##n##) which we can then map back to the original set via a similarity transformation (as defined above), or are there other reasons for diagonalising the system?
Your guess is right. Looking at the eigenstructure turns a multidimensional problem into several independent single-dimensional ones. Since the operator A acts in such a simple way on each eigenvector, they can be easily analyzed one at a time without worrying about the other eigenvectors. Once the problem is solved for all the eigenvectors, the solution can be translated back into the original coordinates.
Ah ok, so is that all there is to it then? The idea being that one starts off with a complicated system of ##n## coupled differential equations, and by diagonalising, one can reduce the problem to studying ##n## independent single dimensional differential equations, massively simplifying the situation.
Yes. In fact a lot of times, you aren't even interested in translating the answers from the eigenstructure back to the original coordinates. You already know important things like modes, stability, etc. In control law design, there is an approach called "eigenspace assignment". In that approach, the desired behavior is specified in terms of the desired eigenspace values and the control laws try to achieve those values.
Cool, thanks for your help.
Related to Diagonalising a system of differential equations
1. What does it mean to "diagonalise" a system of differential equations?
Diagonalising a system of differential equations means to transform the system into a simpler form, where the equations are uncoupled and can be solved independently. This is often done by finding a new set of variables that are linear combinations of the original variables.
2. Why is it important to diagonalise a system of differential equations?
Diagonalising a system of differential equations can make it easier to solve and analyze. It allows us to understand the behavior of the system in terms of the individual equations rather than as a complex set of interrelated equations.
3. How do you diagonalise a system of differential equations?
To diagonalise a system of differential equations, we first need to find the eigenvalues and eigenvectors of the coefficient matrix. Then, we use these eigenvectors to transform the system into a diagonal form. This can be done by taking the inverse of the eigenvector matrix and multiplying it with the original system.
4. What is the significance of eigenvalues and eigenvectors in diagonalisation?
Eigenvalues and eigenvectors play a crucial role in diagonalising a system of differential equations. Eigenvalues represent the growth rates or decay rates of the system, while eigenvectors represent the directions of the associated changes. These values help us understand the behavior of the system and make it easier to solve.
5. Are there any limitations to diagonalising a system of differential equations?
Yes, there are limitations to diagonalising a system of differential equations. This method can only be applied to linear systems, and it may not always be possible to find a set of eigenvalues and eigenvectors. In some cases, the system may need to be approximated or solved using numerical methods instead.
  • Differential Equations
