MHB Diagram Chasing .... Simmons Example 2.1.2 .... .... very basic question ....
  • Thread starter Thread starter Math Amateur
    Diagram Example
Math Amateur
MHB
I am reading the book: "An Introduction to Category Theory" by Harold Simmonds and am currently focused on Section 2.1: Diagram Chasing ...
I need some help in order to fully understand Example 2.2.1 (b) on page 36 ... ...
Example 2.1.2 reads as follows:
https://www.physicsforums.com/attachments/8385
https://www.physicsforums.com/attachments/8384In Example (b) above we read the following:
" ... ... It is not hard to find an appropriate example in Set. Simply let l collapse a lot of elements to the same element. ... ... "Can someone explain (perhaps including a simple example ...) how letting l be such that it collapses a lot of elements to the same element, can lead to the left hand triangle not commuting ... Hope someone can help ...
Peter
Hi Peter,
How about taking each node to be the set $\{0,1\}$, where $f, g, $ and $l$ take both 0 and 1 to 0, and $h$ and $k$ are the identity maps?
GJA said:
Hi Peter,
HI GJA ... thanks for the suggestion ...
I've done the calculations... and yes ... the outer cell and the right hand triangle commute ... yet the left hand triangle does not commute ...
BUT ...
I still cannot "see" what is happening and exactly why the function $l$ collapsing 0 and 1 to the element 0 causes this ...
Can you help? Sorry if I'm being slow in this matter ...Peter
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
