Diamagnetism and orbital magnetic moment
In summary, when an external magnetic field is applied to diamagnetic materials, the orbital magnetic moment of the electrons speeds up in the opposite direction. This happens because the magnetic field through the orbit decreases and the electron must revolve faster to conserve its initial magnetic moment. However, it is important to note that the classical model of an electron orbiting the nucleus is not applicable when considering the effects of a magnetic field on an atom, and the Zeeman effect must be used to accurately describe the behavior of atoms in a magnetic field.
AdityaDev
527
33
For diamagnetic materials, when an external magnetic field is applied, the electrons having orbital magnetic moment in opposite directions spped up.
how does this happen?
The direction of magnetic momwnt is given by right hand thum rule. If there is an electron revolving in anticlockwise direction, magnetic moment is upwards and magnetic field is upwards. So when external magnetic field is applied in downward direction, the magnetic field through the orbit decreases because the two magnetic fields cancel each other. So the electron has to revolve faster to conserve the initial magnetic moment. Is this the reason?
The electron does not feel its own field (at least not in ways relevant here). The magnetic field just leads to an additional inwards(?) force for those electrons.
I got it. When an external magnetic field is applied, the force evB will either increase or decrease the centripetal force depending on the direction of rotation of the electron. If centripetal force decreases, the velocity of electron decreases and so the magnetic moment decreases.
It sounds like you are trying to apply classical physics to atoms, which are quantum objects. You can't treat the electron as classically orbiting around the nucleus. The effect of the magnetic field on an atom is better described using the Zeeman effect. For the simpler cases of diamagnetic materials where the spin is 0, you have the normal Zeeman effect, where you have coupling between the orbital motion and the field. The energy levels are split so some are lower energy and some are higher energy than the no field case, but when the orbital is filled, then the total energy is slightly higher, so the field repels the atom.
In a paramagnetic atom, spin is nonzero, in which case you have coupling between the orbital magnetic moment and spin magnetic moment, and the picture of an electron orbiting the nucleus is even more untenable. Only the lower energy levels in some orbital gets filled, so Zeeman splitting causes a decrease in total energy and the atom is attracted to the field.
Likes AdityaDev
Related to Diamagnetism and orbital magnetic moment
1. What is diamagnetism?
Diamagnetism is a property of certain materials where they exhibit a weak repulsion to an applied magnetic field. This is due to the induced magnetic moment opposing the external field.
2. How does diamagnetism differ from paramagnetism and ferromagnetism?
Diamagnetism is the weakest type of magnetism and is present in all materials. It is characterized by the induced magnetic moment always being in the opposite direction of the external field. In contrast, paramagnetism is a stronger form of magnetism where the induced magnetic moment aligns with the external field, and ferromagnetism is even stronger where the materials can retain their magnetization even after the external field is removed.
3. What is the orbital magnetic moment?
The orbital magnetic moment is the magnetic moment that arises from the orbital motion of electrons around the nucleus. It is one of the two components of the total magnetic moment of an atom, the other being the spin magnetic moment.
4. How is the orbital magnetic moment related to diamagnetism?
The orbital magnetic moment is responsible for the diamagnetic behavior of materials. When an external magnetic field is applied, the orbital magnetic moments of the electrons oppose the field, leading to the weak repulsion observed in diamagnetic materials.
5. Can diamagnetism be observed in everyday materials?
Yes, diamagnetism can be observed in everyday materials such as water, wood, and plastic. However, the effect is very weak and can only be observed in the presence of a strong magnetic field.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
